Member: 213681
Thanks Meter: 108 | Nokia 5530 no power on only vibrate Hi
i have problem with nokia 5530 the phone is not power on only vibrate!
i fleshed this set with last soft 40.0.003 but the problem is the same
Log from mx: Quote:
Processing MCU file: RM-504_40.0.003_prd.core.C00
[BB5,XSR 1.5] size: 105.24 MB
Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 0C90010DEC8800525148ED3CAF151878EE260DC7
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Loading CMT update server data
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 158.19 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: F2B05364 [RAP Certificate 168 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 1 min 40.062 s
Processing PPM file: RM-504_40.0.003_prd.rofs2.V06
[BB5,XSR 1.5] size: 24.15 MB
Erase size: 32 MB
CMT FLASH,MuxOneNAND area [07360000-0935FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 23.515 s
Processing PPM file: RM-504_40.0.003.303.01_prd.rofs3.fpsx
[BB5,XSR 1.5] size: 10.62 MB
Erase size: 11 MB
CMT FLASH,MuxOneNAND area [09360000-09E5FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 10.343 s
Processing CNT file: RM-504_32.0.007_001_000_U002.uda.fpsx
[BB5,XSR 1.5] size: 2.25 MB
Erase size: 88.75 MB
CMT FLASH,MuxOneNAND area [09E60000-0F71FFFF]
Programming completed in 3.140 s
Total time for flashing process(boot+erase+write) was 2 min 28.250 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 37E12B16
| Any idea how fix this?? thanks |
