08-04-2011, 11:04 | #31 (permalink) |
Junior Member Join Date: Jul 2011 Location: davao city mindanao
Member: 1612248 Status: Offline Sonork: 100.1606154 Thanks Meter: 4 | good idea sir and keep it share... keep up the good work sir |
The Following User Says Thank You to ivandota For This Useful Post: |
08-04-2011, 13:25 | #32 (permalink) |
Junior Member Join Date: Jun 2011 Location: Georgia Age: 33
Member: 1599078 Status: Offline Thanks Meter: 1 | hello everybody, I've next problem: nokia 5230 and 5800 have the same problem, they don't power on, when I press power on button,no vibration and display lights dimly and does nothing, HWK can't check/read info... what happens? has anybody solved same problem? please help me |
The Following User Says Thank You to tumana777 For This Useful Post: |
08-10-2011, 23:01 | #36 (permalink) |
Freak Poster Join Date: Dec 2009
Member: 1189245 Status: Offline Sonork: [email protected] Thanks Meter: 13 | please i have nokia 5530 anytime i call immediately they pick the phone we off himself, OR if they call me when i pick it will off please what is the solution i try to flash the phone did not connect direct with hwk, and i used mxkey with usb it does not connect please help |
08-10-2011, 23:48 | #37 (permalink) |
Freak Poster Join Date: Jul 2007 Age: 42
Member: 550190 Status: Offline Sonork: 100.1641265 Thanks Meter: 51 | Many Many Thanks For Your Usfull Solution... Many Many Thanks For Your Usfull Solution... |
The Following 2 Users Say Thank You to ..::MobileSolution::.. For This Useful Post: |
09-14-2011, 07:03 | #41 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 686254 Status: Offline Thanks Meter: 46 | MXKEY Serial: [FT SCR2000 0] - C0####### Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: RM-625_50.1.001_prd.core.C00 [BB5,XSR 1.6] size: 95.73 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 4FE7CAE CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 07400119B0930052540F629092F2FF478CA068F4 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 1 min 38.265 s Processing PPM file: RM-625_50.1.001_prd.rofs2.V21 [BB5,XSR 1.6] size: 12.04 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 36.50 MB CMT FLASH,MuxOneNAND area [06CE0000-0915FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 12.500 s Processing CNT file: RM625_50.1.001_000_000_U001.uda.fpsx [BB5,XSR 1.6] size: 17.05 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Flash programming ... Programming completed in 19.469 s Total time for flashing process(boot+erase+write) was 3 min 0.047 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 4FE7CAE Waiting for USB device removal ...OK Waiting for USB device arrival ... Warning: Phone did not reboot to normal mode. Help me...................... |
09-26-2011, 04:09 | #42 (permalink) |
Junior Member Join Date: Jun 2009 Location: Bangalore
Member: 1059129 Status: Offline Sonork: 100.79167 Thanks Meter: 6 | hello dear members i have nokia 5233 battery backup problem after replacing with new battery still the problem is same plz help Last edited by meeran49; 09-26-2011 at 04:15. |
10-11-2011, 04:13 | #44 (permalink) |
Junior Member Join Date: Feb 2010
Member: 1226585 Status: Offline Sonork: [email protected] Thanks Meter: 0 | thanx to all bros v v v thnax |
