05-31-2009, 16:43 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1032614 Status: Offline Thanks Meter: 46 | nokia 5800 charging fault i am facing problem with 5800 3.7 volt out and fault charging but charging not stored always shows low battery please help |
The Following 4 Users Say Thank You to fuadgsm For This Useful Post: |
05-31-2009, 18:14 | #5 (permalink) |
Freak Poster Join Date: Nov 2005 Location: Slovakia
Member: 196497 Status: Offline Thanks Meter: 54 | N2300,schematic is http://marek.pnet.sk/schematic/index.php |
01-26-2010, 16:23 | #7 (permalink) |
Junior Member Join Date: Jul 2008
Member: 807038 Status: Offline Thanks Meter: 3 | not charging- solution I have problem not charging in nokia 5800, phone was dropped. I check track: start from x2000-> f2000-> L2000> r2000(broken and i replaced)- still not charging,next is c2001->c2000 -ok ,next is n2300 :/ but i find r2071 is missing - this is BSI temp 47k termistor and i take from 6303 this part and now phone charging So 2300 is last thing what we can replaced. Any time we check small components first. |
The Following 3 Users Say Thank You to szpila For This Useful Post: |
05-29-2010, 07:49 | #9 (permalink) | |
Junior Member Join Date: Jul 2005 Location: India Age: 51
Member: 161718 Status: Offline Thanks Meter: 5 | where did you found R2000 ? Quote:
05-31-2010, 23:34 | #10 (permalink) |
Member: 807038 Status: Offline Thanks Meter: 3 | Any bb5 nokia have this component, you have to searching in schematic, should be r2000 the same name in charging block. I take from 6303 or 5300 i think. You remamber correct soldering (.) dot in correct place. |
06-21-2010, 07:55 | #14 (permalink) |
Freak Poster Join Date: Nov 2006 Location: UAE
Member: 383297 Status: Offline Sonork: 100.1591997 Thanks Meter: 54 | Is there take amphere ? If doesn't take amphere u must have chenge charging ic ( betty) And also u will get shematics from Shrak-mobile - flash files, software, schematics, solutions, service manuals for cellular phones |
nokia 5800 firmware unlock this model | simlock | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 04-09-2010 11:22 |
charging prblem to nokia 5800 | hamada-almasry | Nokia Hardware & Hardware Repair | 3 | 01-06-2010 02:59 |
nokia 5800 not charging | jasir_kp | Nokia Hardware & Hardware Repair | 2 | 04-18-2009 05:36 |
Nokia 1100 Charging Fault | vanderwaltn | Nokia Hardware & Hardware Repair | 3 | 03-13-2005 13:33 |
