Old 02-02-2010, 13:53   #1 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
Arrow Nokia 5800 disply show black when keep rest
Plz..... help
About nokia 5800.when i keep my set at rest,after few menets when i go to use set fast click display dose not work.display stay black then dose work.what can be solustion this problem.please help me all of foram sir.
1st time display
Then display
The Following 2 Users Say Thank You to bappi1 For This Useful Post:
Old 02-02-2010, 14:06   #2 (permalink)
jahednn's Avatar
Member: 790856
Thanks Meter: 532
5800 10000% display solution
if black screen with above solution problem not solve, but if standy by position screen normal and if keylock and than your open keylock you see screen line...above solution is solve..........regards by jahed1986
The Following 9 Users Say Thank You to jahednn For This Useful Post:
Old 02-02-2010, 14:11   #3 (permalink)
jahednn's Avatar
Member: 790856
Thanks Meter: 532
NOKIA 5800 light solution..
this solution is to all of you
the promblem is no light on lcd
screenshot:
this is 100% solution.
i hope this solution can help you..
The Following 12 Users Say Thank You to jahednn For This Useful Post:
Old 02-07-2010, 15:35   #4 (permalink)
bappi1's Avatar
Member: 517801
Sonork: 100.1594355
Thanks Meter: 316
I could't understand ur solution plz tel me doing easy sir.
The Following 3 Users Say Thank You to bappi1 For This Useful Post:
Old 02-07-2010, 15:40   #5 (permalink)
nsns285's Avatar
Member: 80869
Sonork: 100.1638021
Thanks Meter: 94
good solution thanks........
The Following 4 Users Say Thank You to nsns285 For This Useful Post:
Old 02-08-2010, 11:30   #6 (permalink)
rajasekar's Avatar
Member: 503989
Thanks Meter: 71
good job brother, keep posting ....
The Following 3 Users Say Thank You to rajasekar For This Useful Post:
Old 05-07-2010, 02:46   #7 (permalink)
Member: 909444
Thanks Meter: 25
wow!!!Muak................ love u man jahednn
thaks for sharing!!!
The Following 2 Users Say Thank You to ssshsss For This Useful Post:
Old 06-20-2010, 12:15   #8 (permalink)
Member: 1012165
Thanks Meter: 116
hi i successfully fixed this problem on a 5800 but the little problem i have is that when the phone goes on stand bye mode and i use the side lock button to release it, it shows normal unlike before when it goes multi colored,but now when it goes on stand bye and i tap the screen (even when the key lock is disabled )it does not pick up i.e it does not show the normal screen instead it still shows black then occasionally multicolored till i push the side key lock keypad that is when it shows normal,i placed the magnet on the flex just above the the center top of the screen if it not properly placed, pls let me know and is it supposed to be a small piece of magnet or many tiny pieces of magnet?pls help what do i do to have a complete and permanent solution.thanks in advance
The Following 3 Users Say Thank You to tonywireless For This Useful Post:
Old 03-21-2011, 17:25   #9 (permalink)
jahednn's Avatar
Member: 790856
Thanks Meter: 532
so easy bro...................1000% ok solution
Old 03-21-2011, 20:01   #10 (permalink)
Member: 952449
hiiiiiiiiiiiii excellent job keep it uppp
The Following User Says Thank You to sailajakrishna For This Useful Post:
nokia 5800 display turns off when incoming and outgoing call joelcabuyaban Nokia Hardware & Hardware Repair 62 01-13-2014 07:59
nokia 5800 disply light febialpy Nokia Hardware & Hardware Repair 6 10-20-2010 15:07
Nokia 5800 - just shows Nokia and goes off c1rca Nokia Base Band 5 ( BB-5 ) 7 08-20-2009 09:42
Refurbished Nokia 5800 Phone (unlocked) - Black IPMART ipmart WebShop 0 07-06-2009 10:30
Front and Back Color Plate Housing for Nokia 5800 Phone (PVC) - Black IPMART ipmart WebShop 0 03-16-2009 12:10
Page generated in 0.19945 seconds with 10 queries
