06-28-2010, 12:31 | #1 (permalink) |
Registered User Join Date: Aug 2003 Location: ALGERIA ,DZ
Member: 37521 Status: Offline Thanks Meter: 50 | Nokia 5800 lcd problem only with SIM I have nokia 5800 with lcd problem (lines in lcd) ,this happend only with sim card (without sim = no problem in lcd) is there any solution for this problem. thanks. |
The Following User Says Thank You to gsmfriend For This Useful Post: |
06-28-2010, 14:59 | #5 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: USA
Member: 85637 Status: Offline Sonork: 100.100.529 Thanks Meter: 139 | Quote:
if its not working try pm or check if the phone was foll in the water Mr. Anilmply if u have something to help hem say , if not don't post take look and go and try to look first , gsmfriend is in this forum 2003 that mean he is here before u 7 years so for sure he know how to use this forum for help hem self and search not serch yeah the front camera can make that if u work on 3g sim network | |
06-28-2010, 15:06 | #6 (permalink) |
Member: 37521 Status: Offline Thanks Meter: 50 | hello thanks a lot friends this is may phone state it was fall in water , I have flash it ,clean the board ,change lcd but no luck I met this problem before ,but always lcd problem with or without sim but in my case the lcd problem is only when insert sim card. I have seen many temporary solution ,tested but not working. OK, any suggestion U R Welcome. thanks. |
06-28-2010, 15:12 | #7 (permalink) | |
first u have to clean it very well then try to change B2170 or u have to change Avilmas ic good luck | |
06-30-2010, 11:58 | #9 (permalink) |
Freak Poster Join Date: Jul 2007
Member: 547621 Status: Offline Thanks Meter: 20 | Hello with all!! Here my problem concerning the nokia 5800: When I déverouille my nokia, l' screen appears encrypted (like canal+ into encrypted), scrambled and l' screen is illegible… This does it 9 times out of 10 when I dévérouille the portable and can last a long time… 3 seconds with Plus of 5 min… Quelqu' this problem has? What is necessary to make? Y-a it of the solutions? Thank you very much… |
06-30-2010, 11:59 | #10 (permalink) |
Member: 547621 Status: Offline Thanks Meter: 20 | nokia 5800 problem veroillage Hello with all!! Here my problem concerning the nokia 5800: When I déverouille my nokia, l' screen appears encrypted (like canal+ into encrypted), scrambled and l' screen is illegible… This does it 9 times out of 10 when I dévérouille the portable and can last a long time… 3 seconds with Plus of 5 min… Quelqu' this problem has? What is necessary to make? Y-a it of the solutions? Thank you very much… |
07-01-2010, 19:57 | #11 (permalink) |
Member: 37521 Status: Offline Thanks Meter: 50 | hi friend here is temporary solution to your problem when your display goes scrambled (lines in display when unlock or lock keypad) then press side camera button and after camera came on the put your finger in front of camera len for two seconds the the display will be in normal state. good luck. |
