Nokia 5800 screen goes black as making a call hi bros i have Nokia 5800 its screen goes black as i make a call i formate it n did the UI setting but the problem is still there help me in solving the problem thanks in advance |
Nokia 5800 lcd blank when make call 1 Attachment(s) NOKIA 5800 LCD BLANK WHEN MAKE CALL Sorry If it's Double post Problem Nokia 5800 LCD BLANK When Make a Call Reason : Sensor Modul for save energy it's too sensitive FIX Way : -Change sensor modul with normal one -OR use some TRIKS For Fix LIKE A PICTURE Below (REMEMBER TRIKS NOT PERFECT AT ALL!!!) Attachment 262716 |
the only and one perfect solution is changing the sensor,if you dont have sensor put the dark tape across the sensor like picture upsaide this is perfect and chepeast solution..and must important...WORKING.....:D:D:D |
yes. its sensor problem. u make sure lcd and touch assembly . there have this problem. br h.mamun |
the only and one perfect solution is changing the sensorhttp://www.computertap.com/26.jpghttp://www.computertap.com/10.jpg |
