Nokia 6030 Charging Problame Hi, Iam Babu Pls I Have Problem Abut Provlame Nokia 6030 Charging Problame. When I Canected Mobile With Charger Then Not Showing Anything In Monitor. Pls Send Me Solve. Thanks, Babu |
If 'not Charging' Is Indicated On The Display, I Could Be Talking Of The Charging Block Glass Ic, But Now Since Nothing Is Shown On The Display, You Need To Ascertain The Functionality Of The Charger. If The Charger Is Okay, Check The Dc Jack Port Where The Charger Plug Is Inserted For Presence Of Charge Voltage. Do This By Cheking With Multimeter Tester With Range Switch Set At 20 Volts And Then Apply The Two Leads Of The Meter On The Two Pins Of The Charging Port. Perhaps The Phone Is Suffering From A Damaged Port. Good Luck. |
yeah,what is Mr ABUU say Is right,if u try all this and the problem still same,the only way u must try 2 replace/change UEM ic!!! good look |
check charging fuse friend..................:) |
very good suggestions thanks to all |
thank plz send pic and i have + and - way when connect i hear sound so found short how solve it plz |
6030 not charging 1 Attachment(s) Quote:
6030 audio 1 Attachment(s) Quote:
superb suggestion from Abuu & Boengo................... Thanks to all |
