Old 08-15-2007, 09:25   #1 (permalink)
DIGITAL BABU's Avatar
Member: 420857
Sonork: 100.1576793
Thanks Meter: 1,734
Nokia 6030 Charging Problame
Hi, Iam Babu
Pls I Have Problem Abut Provlame Nokia 6030 Charging Problame. When I Canected Mobile With Charger Then Not Showing Anything In Monitor. Pls Send Me Solve.
Thanks,
Babu
The Following 2 Users Say Thank You to DIGITAL BABU For This Useful Post:
Old 08-15-2007, 11:27   #2 (permalink)
ABUU YUUNUS's Avatar
Member: 319112
Thanks Meter: 164
If 'not Charging' Is Indicated On The Display, I Could Be Talking Of The Charging Block Glass Ic, But Now Since Nothing Is Shown On The Display, You Need To Ascertain The Functionality Of The Charger. If The Charger Is Okay, Check The Dc Jack Port Where The Charger Plug Is Inserted For Presence Of Charge Voltage. Do This By Cheking With Multimeter Tester With Range Switch Set At 20 Volts And Then Apply The Two Leads Of The Meter On The Two Pins Of The Charging Port. Perhaps The Phone Is Suffering From A Damaged Port. Good Luck.
Old 08-15-2007, 11:41   #3 (permalink)
joni_yang's Avatar
Member: 560754
Thanks Meter: 289
yeah,what is Mr ABUU say Is right,if u try all this and the problem still same,the only way u must try 2 replace/change UEM ic!!! good look
Old 08-15-2007, 12:05   #4 (permalink)
tabuki's Avatar
Member: 455665
Thanks Meter: 36
check charging fuse friend..................
Old 08-21-2007, 08:23   #5 (permalink)
Member: 514743
Thanks Meter: 4
very good suggestions
thanks to all
Old 10-24-2007, 21:38   #6 (permalink)
Member: 64946
Thanks Meter: 5
thank
plz send pic and i have + and - way when connect i hear sound so found short how solve it plz
Old 10-24-2007, 22:09   #7 (permalink)
boengo's Avatar
Member: 401010
Thanks Meter: 103
6030 not charging
u r mean it's u have same prob bro?...i have this trick
Old 10-24-2007, 22:19   #8 (permalink)
boengo's Avatar
Member: 401010
Thanks Meter: 103
6030 audio
this speaker problem
Old 08-26-2013, 07:31   #9 (permalink)
Member: 1826830
Sonork: Narayan Roy
superb suggestion from Abuu & Boengo................... Thanks to all
Nokia 1110-1600-6030 charging solution r a nadeem Nokia Hardware & Hardware Repair 70 09-07-2012 15:18
nokia 6030 restart problam pleas halp me. azizby02 Nokia Hardware & Hardware Repair 1 11-07-2009 18:15
nokia 6030 restart problam pleas halp me. azizby02 Nokia Hardware & Hardware Repair 0 11-07-2009 18:06
nokia 6030 light problame sachin_udai Nokia Hardware & Hardware Repair 1 10-26-2008 17:25
Not Charging Nokia 6030 Lucky Assad Nokia Hardware & Hardware Repair 3 09-03-2008 14:44
Page generated in 0.28109 seconds with 10 queries
