Old 06-16-2006, 12:40   #1 (permalink)
Member: 260672
Thanks Meter: 20
Nokia 6030 "Not Charging"
Hi Guys,
i have a problem with my nokia 6030 ...when i plug the phone for charging the phone says "Not charging",... I am using the original Charger provided with the phone but now it says "Not Charging"....can any body provide me the solution for this problem.
thanx in advance
ThoYYu
The Following 2 Users Say Thank You to thoyyu For This Useful Post:
Old 06-16-2006, 13:40   #2 (permalink)
swapnilbombay's Avatar
Member: 268495
Thanks Meter: 27
first check the battery connector & the middle point of the battery connector and the components related battery connector best of luck !!
Old 06-16-2006, 16:47   #3 (permalink)
Member: 281239
Thanks Meter: 18
try change batt....good luck
Old 06-16-2006, 17:21   #4 (permalink)
..::ArchitRaj::..'s Avatar
Member: 181696
Sonork: 100.107830
Thanks Meter: 5,406
change batery and chek charging components
Old 06-16-2006, 17:42   #5 (permalink)
Member: 260672
Thanks Meter: 20
Thanx guys for ur fast response....i will check it out.....pls do tell me which components to i shud check thats related to battery
Old 07-04-2006, 14:18   #6 (permalink)
Member: 97502
Thanks Meter: 4
try to cleen phone and reheat carfully on uem good luck
Old 07-04-2006, 20:54   #7 (permalink)
Member: 300263
check battery terminal may be it doesnt have a contact against ur battery thats why it indicates not charging if the battery terminal has no problem check ur charging ic
Old 07-05-2006, 02:27   #8 (permalink)
Member: 38922
Thanks Meter: 35
Mostly UEM defective.
_____________________
www.cybermobile.org
Old 07-06-2006, 13:06   #9 (permalink)
Member: 305678
try to put pm file, *** luck
Old 07-06-2006, 22:11   #10 (permalink)
Member: 306943
Thanks Meter: 2
6030 charg solution
Originally Posted by thoyyu
Hi Guys,
thanx in advance
ThoYYu
nokia 6030 not charging solution
first one solution : to remove the bsi terminal contact components (middle).
2nd ;one " : to remove the resister (below the simbed , which one of the resister to contact bsi terminal )
Old 07-07-2006, 09:41   #11 (permalink)
Yache's Avatar
Member: 181394
Thanks Meter: 3
thanks for your explanations
but i think pictures would help
do you have any
pls post here
br!
Old 07-11-2006, 05:58   #12 (permalink)
Member: 91180
Thanks Meter: 22
hi,
it dont work for me any other solution
Old 07-17-2006, 08:04   #13 (permalink)
Member: 215651
Thanks Meter: 7
any body help in charging problem??????????????????????????
Old 07-23-2006, 10:50   #14 (permalink)
gsm-iran's Avatar
Member: 188646
Thanks Meter: 76
hi everybady
chang charging i c after chack original Charger provided
ok
thanks .....
Old 01-09-2009, 14:35   #15 (permalink)
Member: 215766
nokia not charging solution picture (Try n Enjoy)
1100 2300 not charging
2600 not charging
2610 not charging
2650 not charging
3100 not charging
3200-7250 not charging
3230 not charging
3250 not charging
3510 not charging
6020 not charging
6030 not charging
6070 not charging
6100 not charging
6101 not charging
6111 not charging
6600 not charging
6670 not charging
6680 not charging
n70 not charging http://rapidshare.com/files/41144162/not_charging.rar
NOKIA 6030 "not charging" comming suddenly ameerali19 Nokia Hardware & Hardware Repair 3 04-08-2009 07:29
Nokia 8310 "Not Charging" gorans Nokia Digital Core Technology 4 ( DCT-4 ) 6 09-16-2004 02:19
Nokia 8310 "Not Charging" gorans Nokia Digital Core Technology 4 ( DCT-4 ) 5 07-05-2004 18:01
Nokia 3310 "NOT CHARGING" jamestyl Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 05-02-2004 15:41
Nokia 7110 "not charging" Sekoel Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-11-2001 12:01
Page generated in 0.24921 seconds with 10 queries
