Nokia 6030 "Not Charging" Hi Guys, i have a problem with my nokia 6030 ...when i plug the phone for charging the phone says "Not charging",... I am using the original Charger provided with the phone but now it says "Not Charging"....can any body provide me the solution for this problem. thanx in advance ThoYYu:) |
first check the battery connector & the middle point of the battery connector and the components related battery connector best of luck !! |
try change batt....good luck |
change batery and chek charging components |
Thanx guys for ur fast response....i will check it out.....pls do tell me which components to i shud check thats related to battery |
try to cleen phone and reheat carfully on uem good luck |
check battery terminal may be it doesnt have a contact against ur battery thats why it indicates not charging if the battery terminal has no problem check ur charging ic |
try to put pm file, *** luck |
6030 charg solution Quote:
first one solution : to remove the bsi terminal contact components (middle). 2nd ;one " : to remove the resister (below the simbed , which one of the resister to contact bsi terminal ) |
but i think pictures would help do you have any pls post here br! |
hi, it dont work for me any other solution |
any body help in charging problem?????????????????????????? |
hi everybady chang charging i c after chack original Charger provided ok thanks ..... |
nokia not charging solution picture (Try n Enjoy) nokia not charging solution picture 1100 2300 not charging 2600 not charging 2610 not charging 2650 not charging 3100 not charging 3200-7250 not charging 3230 not charging 3250 not charging 3510 not charging 6020 not charging 6030 not charging 6070 not charging 6100 not charging 6101 not charging 6111 not charging 6600 not charging 6670 not charging 6680 not charging n70 not charging http://rapidshare.com/files/41144162/not_charging.rar http://www.mobile-files.com/forum/im...er_offline.gif http://www.mobile-files.com/forum/im...reputation.gif |
