Old 04-19-2007, 11:18   #1 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 964
Arrow nokia 6060 flshing problem in jaf and ufs stops in the middle of flashing screen shot
Languages in ppm: English,Chinese S,Chinese T (Taiwan)
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-73\rh73_74__4.100
Booting phone...
MCU ID: 0x2031
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.3D.00 -> Revision: 0007
Boot size is 0x0958
Boot is ready...
FLASH ID0: 00012C7E -> AMD Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
FLASH ID1: 00000001 -> NOT USED Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0x7E2C0100
Flash loader is C:\Program Files\ODEON\JAF\Flash\u_amd.fia
Loader size is 0x6F80; Loader chk: 4
Loader is ready...
P-key nokia module version 01.00
MSID: 8473CA18B00B6BA16BAE70D9C8
MSID decoded: 8575BAE900C7238CA8000000
FAID: D146144A14286B4B9FF9DD2A
Operation took 0 minutes 18 seconds...
Erasing...
Found 3 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 0187FFFF...
Error erasing area: 01220000 - 0123FFFF
This problem coming in jaf
1st Boot Ok, DCT4, UPP: 2031
Fl0: 0x01000000-0x01FFFFFF,00012C7E,Amd No Name
Algorithm: u_amd.fia, Ver: 4.49.0
Algorithm Ok, MSID: 8473CA18B00B6BA16BAE70D9C8
Decoded MSID: 8575BAE9-00C7238C-A8000000
Encoded FAID: BD9AE9E9-7EE4BA94-1F328C09
Area1: 0x01000000-0x0101FFFF Erased, Time: 00:00
Erasing: 0x01020000-0x0187FFFF ...
Erasing Error: 4, at: 0x01380000-0x0139FFFF, Time: 01:30
Process Failed, Repowering Mobile
This problem is coming in ufs
Please help me on this problem
Regaurds
Asghar hussain
Old 04-19-2007, 11:20   #2 (permalink)
Member: 475440
Sonork: 1604067
Thanks Meter: 964
please help and check this threet
Old 04-19-2007, 14:17   #3 (permalink)
Member: 486960
Thanks Meter: 45
This is 99percent IC flash failure. Because the process stop at erasing flash. Just rehot the IC first.
Old 04-19-2007, 14:28   #4 (permalink)
Yuvi's Avatar
Member: 226587
Sonork: 100.1603781
Thanks Meter: 352
change the upp your problem is solve
b,r
yuvi,
Old 04-19-2007, 15:19   #5 (permalink)
Member: 76716
Thanks Meter: 15
Hi friend,
Before doing any thing just clean your set with good Isoprophile(I.P.A.) cleaner, Then give moderate heat to flash IC.
Then Just click on full erase in JAF.
Again select Flash erase chip list and erase one by one.
Then flash MCU+PPM+CNT+PM+UI setting.
This is my method for the cell which stop in middle of erasing or flashing.
All the best.
Old 04-19-2007, 19:16   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,338
yes problem is in flash ic you first reflow or reball it if not work then change it with new one
good luck
post result
Old 04-20-2007, 10:43   #7 (permalink)
Member: 475440
Sonork: 1604067
Thanks Meter: 964
i am very thankfull you all now i will try these and i will post u the result
Old 05-28-2009, 10:23   #8 (permalink)
gsmsikar's Avatar
Member: 28004
Sonork: 100.1601142
Thanks Meter: 768
i am also have this same problem in a 6060
erasing error
1st Boot: Ok, DCT4, UPP: 2031 [Rh-73] [2.0.8.4]
2nd Boot: u_2nd.fia, Ver: 4.76.0
Fl0: 0x01000000-0x01FFFFFF,00012C7E,Amd 29NS128N
Algorithm: u_amd.fia, Ver: 4.76.0
Algorithm Ok, MSID: 8426496C57ECBB6F8A04C77A46
Decoded MSID: F6D3BAE9-00102028-A9000000
Encoded FAID: A07719C9-17E65820-853D4C66
IMAGE: rh73_74__5.110
Erasing Error: 8, at: 0x01260000-0x0127FFFF, Time: 02:13
what is the solution ?
Old 05-28-2009, 11:58   #9 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,338
same answer mate reflow or reball flash ic otherwise replace (if your cable is ok also try with jaf first)
CU500 DEAD in the middle of Flash-unlocking (Cant enter Emergency Mode) dannyogolo FuriousGold 7 09-28-2007 23:34
nokia 6060 stops in the middle of flash please help mobilecitycbk Nokia Hardware & Hardware Repair 4 04-17-2007 19:16
7610 Dead-flashing In Jaf And Ufs Ok-but Can Not In Mtbox?-reason zonetrichur MT-BOX 4 04-04-2007 11:39
Page generated in 0.31395 seconds with 8 queries
