10-06-2008, 17:23 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: India
Member: 449060 Status: Offline Sonork: 100.1670591 Thanks Meter: 260 | Nokia 6070 flashing Fl0: 0x01000000-0x01FFFFFF,00208804,St No Name Algorithm: u_st_i.fia, Ver: 4.57.0 Alg Boot Error: 2 Error Data1: 00000000: 9F 03 02 01 00 20 88 04 00 00 72 21 11 00 02 00 ..... ....r!.... 00000010: 00 00 01 00 00 00 00 00 00 AD 7E B6 1A 1B BE 0B ..........~..... 00000020: E2 7D 58 6B E4 DB EE 65 14 7F 00 00 00 00 00 00 .}Xk...e....... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: D3 72 20 88 04 00 00 72 21 11 00 02 00 00 00 01 .r ....r!....... 00000010: 00 00 00 00 00 00 AD 7E B6 1A 1B BE 0B E2 7D 58 .......~......}X 00000020: 6B E4 DB EE 65 14 7F D3 72 00 00 00 00 00 00 00 k...e..r....... 00000030: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ Before taking screenshot, expand this window ! plese help |
10-06-2008, 19:23 | #3 (permalink) |
Freak Poster Join Date: Sep 2008 Location: pradise on earth
Member: 856298 Status: Offline Thanks Meter: 64 | hi bro i will define u wat is actual prob error is hear Fl0: 0x01000000-0x01FFFFFF,00208804,St No Name ................ f10 is a main flash ic and st no name means ic is properly connected on its base but ic is not working may be its data is corrpted so now u have to change both fllah ic and uem also. i give u one more example if it shows this Fl0: 0x01000000-0x01FFFFFF,00208804,................. dots means blank space so it means ic s ok but not properly connected with its base than u have to reboll only fash ic. its 100% used nd tested regards hadis obile care nd institute.. |
The Following User Says Thank You to hadis-mobile For This Useful Post: |
10-06-2008, 19:26 | #4 (permalink) |
Member: 856298 Status: Offline Thanks Meter: 64 | hello bro had u seen this thing Fl0: 0x01000000-0x01FFFFFF,00208804,St No Name st no name so how can u say cpu |
10-07-2008, 05:01 | #7 (permalink) | |
Registered User Join Date: Sep 2003 Location: Palestine Age: 50
Member: 39208 Status: Offline Thanks Meter: 152 | Quote:
---- Byte | |
10-07-2008, 05:41 | #8 (permalink) | |
Registered User Join Date: Jan 2008 Location: NARAYANGONJ BANGLADESH Age: 36
Member: 688907 Status: Offline Thanks Meter: 509 | Quote:
03-24-2009, 16:52 | #9 (permalink) |
Freak Poster Join Date: Jan 2007 Location: Mumbai
Member: 434631 Status: Offline Thanks Meter: 77 | 6070 flashing error 6070 flashing error this hand sets mostly have upp problems so when u rehot upp its balls leves from the base off the ic (upp) so u have to reball upp to solve the problem. |
neeed nokia 6070 flash file which support hindi language | gsm_cdma_ufs | Nokia Hardware & Hardware Repair | 1 | 04-29-2009 17:24 |
Req: Nokia 6070 Camere Solution After Flashing | firman al ulum | Nokia Digital Core Technology 4 ( DCT-4 ) | 6 | 11-30-2007 15:34 |
nokia 6070 can't flash | 79mobile | HWK | 5 | 10-16-2007 08:05 |
