Old 09-23-2008, 15:40   #1 (permalink)
rashel.com's Avatar
Member: 460857
Thanks Meter: 804
Nokia 6085 blue screen solution
need Nokia 6085 blue screen solution
when i power on the disply blue but net ok call ok
please help
The Following User Says Thank You to rashel.com For This Useful Post:
Old 09-23-2008, 15:46   #2 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Hello bro first change ribon & post result
The Following User Says Thank You to Shantobhai For This Useful Post:
Old 09-23-2008, 15:49   #3 (permalink)
Member: 228508
Thanks Meter: 55
change to flex.......
The Following User Says Thank You to halilibrahim For This Useful Post:
Old 09-23-2008, 16:00   #4 (permalink)
rashel.com's Avatar
Member: 460857
Thanks Meter: 804
change ribon result same.....
Old 09-23-2008, 16:19   #5 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
R u chang display? y or not post result
Old 09-24-2008, 06:56   #6 (permalink)
rashel.com's Avatar
Member: 460857
Thanks Meter: 804
yes change display result same
Old 09-24-2008, 07:03   #7 (permalink)
gsmshare's Avatar
Member: 429569
Thanks Meter: 1,543
1st you cahnge display,
2nd you change flexi cable,
3rd you cahnge display ic,,,,and if still same must rehot or reball upp,,,,,
try and post result,,,
all the best
Old 09-24-2008, 07:35   #8 (permalink)
Shantobhai's Avatar
Member: 648647
Sonork: 100.1603328
Thanks Meter: 967
Now u change display ic near display conector if not change conector & post result
Old 09-24-2008, 13:19   #9 (permalink)
rashel.com's Avatar
Member: 460857
Thanks Meter: 804
display ic conector change but same problem
Old 04-23-2009, 13:07   #10 (permalink)
Member: 554249
Thanks Meter: 7
brother nust be cheange your display ic and display connector , motherboard connector clean mobile is ok
Old 04-23-2009, 13:18   #11 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Thanks Meter: 4,912
@ belzar
Chak post date don't spamm
09-24-08, 17:49
Old 04-23-2009, 21:22   #12 (permalink)
Member: 816207
Thanks Meter: 37
bro check flat fix cabel and checking lcd
The Following 2 Users Say Thank You to NUOR_GSM LG For This Useful Post:
Old 06-08-2009, 17:35   #13 (permalink)
rajdeepsaw's Avatar
Member: 723195
Thanks Meter: 57
abe tumhara sabhi mein but same problem
Old 08-23-2010, 05:09   #14 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
i neen nokia 6085 all solution
nokia 6085 blue screen reaj Nokia Hardware & Hardware Repair 23 08-22-2011 12:58
6085 blue screen . . . amol_sm Nokia Base Band 5 ( BB-5 ) 2 10-01-2009 04:47
6085..blue screen samirov-gsm Nokia Hardware & Hardware Repair 2 01-06-2009 14:39
nokia 6085 blue screen? ramir chan Nokia Hardware & Hardware Repair 1 07-23-2008 05:18
6085 blue screen mafolk Nokia Hardware & Hardware Repair 4 04-26-2008 08:59
Page generated in 0.20128 seconds with 9 queries
