nokia 6085 camera problem............ sir i have nokia 6085 which is water damage.i clean pcb very well now set on but when i start camera set is auto restart. i flash with new flash file but no result it's strip&camera section was ok i check with other 6085 set plssssssssss give me solution....:confused: |
sir plsssssssss help me ,my problem still not solved.................. |
Bro check by changig its flex cable (strip). May be your problem will be solved |
sir i change flex cable but no result......... |
sir i have nokia 6085 which is water damage.i clean pcb very well now set on but when i start camera set is auto restart. i flash with new flash file but no result it's strip&camera section was ok i check with other 6085 set plssssssssss give me solution.... |
changging the boad of camera it will ok |
re: Quote:
i change cristel ic pro........ not solev |
Did U check flex & camera? |
Getting MCU ID MCU ID: 0x2142 FLASH ID0: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... MCU: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6_6270.6440 Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xFA22EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\m_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x8130; Loader chk: 63 Error Loading loader! pls help 9300 software |
pls helpGetting MCU ID MCU ID: 0x2142 FLASH ID0: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... MCU: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6_6270.6440 Booting phone... MCU ID: 0x2142 BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A0 Boot is ready... FLASH ID0: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0xFA22EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\m_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x8130; Loader chk: 63 Error Loading loader! gsm brothers 9300 software prblm |
sir iam also facing same problem i changed flex strip & flashed handset more than 5 times but there is no use.. help me |
