Old 12-20-2007, 18:55   #1 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
nokia 6085 camera problem............
sir i have nokia 6085 which is water damage.i clean pcb very well now set on but when i start camera set is auto restart. i flash with new flash file but no result it's strip&camera section was ok i check with other 6085 set plssssssssss give me solution....
The Following 3 Users Say Thank You to rk19801 For This Useful Post:
Old 12-21-2007, 10:42   #2 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
sir plsssssssss help me ,my problem still not solved..................
Old 12-22-2007, 03:04   #3 (permalink)
Member: 309867
Thanks Meter: 10
Bro check by changig its flex cable (strip). May be your problem will be solved
Old 12-22-2007, 04:47   #4 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
sir i change flex cable but no result.........
Old 04-06-2008, 12:26   #5 (permalink)
Member: 682732
Thanks Meter: 4
Old 04-06-2008, 12:27   #6 (permalink)
Member: 682732
Thanks Meter: 4
The Following User Says Thank You to manish1500 For This Useful Post:
Old 04-06-2008, 13:40   #7 (permalink)
Member: 475953
changging the boad of camera it will ok
Old 04-07-2008, 14:19   #8 (permalink)
Member: 682732
Thanks Meter: 4
Old 04-07-2008, 17:45   #9 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
Change 2 cristal ic near the boad connector.Sure 100% working.
Old 04-07-2008, 19:23   #10 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 146
re:
" before doing any operation check the voltage at pin no. 2 & 10 respectively (2.8v & 1.8v)"
Old 05-28-2008, 09:52   #11 (permalink)
Member: 465077
i change cristel ic pro........ not solev
Old 05-28-2008, 18:41   #12 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
Did U check flex & camera?
Old 05-28-2008, 19:02   #13 (permalink)
Member: 613484
Thanks Meter: 5
Getting MCU ID
MCU ID: 0x2142
FLASH ID0: 22FA00EC <=> SAMSUNG (SEC) -> K8S6415ETA Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
MCU: C:\Program Files\Nokia\Phoenix\Products\RAE-6\RAE6_6270.6440
Booting phone...
MCU ID: 0x2142
BOOT file: C:\Program Files\ODEON\JAF\Flash\u_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A0
Boot is ready...
Flash ID is 0xFA22EC00
Flash loader is C:\Program Files\ODEON\JAF\Flash\m_amd.fia
Loader size is 0x8130; Loader chk: 63
Error Loading loader! pls help 9300 software
Old 05-28-2008, 19:03   #14 (permalink)
Member: 613484
Thanks Meter: 5
pls helpGetting MCU ID
MCU ID: 0x2142
Algo is ready...
Done!
Phone Restarted...
Booting phone...
MCU ID: 0x2142
Boot size is 0x09A0
Boot is ready...
Error Loading loader! gsm brothers 9300 software prblm
Old 06-24-2008, 09:50   #15 (permalink)
Member: 462076
Sonork: 100.1586314
Thanks Meter: 307
sir iam also facing same problem
i changed flex strip & flashed handset more than 5 times
but there is no use..
help me
nokia 6085 camera problem help me arifm_cools Nokia Hardware & Hardware Repair 2 12-02-2009 08:32
nokia 6085 camera problem help me arifm_cools Nokia Hardware & Hardware Repair 0 07-29-2009 03:17
Nokia 6085 camera problem wase Nokia Hardware & Hardware Repair 5 03-15-2009 08:56
nokia 6085 camera problem gulam khadir Nokia Base Band 5 ( BB-5 ) 1 11-04-2008 20:09
Nokia 6085 Camera Not Working & faded to white.. amit123 Nokia Hardware & Hardware Repair 4 07-28-2008 09:13
Page generated in 0.42150 seconds with 8 queries
