04-09-2006, 21:50 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | 7610 charger detected but not charging... anyone got the charging ways for this one pls? Would not charge at all even if charger is detected. this occured after water damage. Most probably is UEM problem but better be sure. thanks for any help |
08-21-2006, 07:39 | #6 (permalink) |
Junior Member Join Date: Aug 2006
Member: 330751 Status: Offline Thanks Meter: 0 | Nokia Care Service Point Manager: First you need to check if the main board doesn't have humidity rests (Sorry my bad english). I mean, some "white dust" (guess the word is "sulfat") if it exist, please clean the main board whit isoprop. alcohol and a teeth brush. Then with a multimeter (diode test: that one that "beeps" when you have a short) test the fuse. usualy it is at the bottom of the keyboard pad (below the shield on a 3220) it has to beep, if not, then you have to replace it (this is the right way to repair it 'cause the fuse will prevent damages on the circuit). Now if you don't have a "digital fuse" then you can sold a wire in both sides of the fuse... like this... [=K=] ----- It's easy to find the component 'cause it has a "K" letter printed on it. Maybe you need to use a microscope or some augment lenses to make the job. If the fuse is working correctly (I mean fine) then it is a Software problem, in that case you need to: 1.- Upgrade the flash (check version of phone flash file) or 2.- Re-flash the phone. Hope this help you. |
nokia 7610 shows chrging indication but not charge | bijupadavan | Nokia Hardware & Hardware Repair | 5 | 10-14-2008 17:28 |
nokia 7610 shows chrging indication but not charge | nsbalu | Nokia Hardware & Hardware Repair | 1 | 10-14-2008 14:18 |
nokia 7610 shows chrging indication but not charge | bijupadavan | Nokia Hardware & Hardware Repair | 1 | 10-14-2008 14:17 |
L6 Detects Charger But Not Charge | kwamena | Motorola Hardware Repair | 2 | 09-30-2007 19:05 |
3210 shows charging, but not charge actually. | sat | Nokia Hardware & Hardware Repair | 6 | 11-02-2001 01:28 |
