05-09-2007, 04:27 | #1 (permalink) |
Junior Member Join Date: May 2007
Member: 503763 Status: Offline Thanks Meter: 0 | Nokia 6101 keypad key is always pressed The Nokia 6101 i am having woked fine until the number 2 key gave me trouble when I want to use it for texting. At the beginning when i press the key twice or three times I get the charactor I wanted, unlike other keys. Now the entire key pad is not responding (power off works though) as soon as I press any key the number 2 appears in the screen. It is almost that key is pressed by default. If I press number 3 or (any other number) that number will appear followed by number 2 again. Most of the time I hear the number 2 key sound from the phone (bcoz it is pressed) any help highly appreciated. regards, J |
05-09-2007, 16:22 | #2 (permalink) |
Member: 503763 Status: Offline Thanks Meter: 0 | Never mind, I have repaired it. I opened the cover and removed the keypad. Then made a small cut in the thin white sheet over the key contact to reach the conductive pad (which was having a little offset). After placing it properly everything worked fine I still can't figure out what made the conductive pad to have an offset. I am so happy to repair it for $3.19 (Torx #6 screwdriver from sears) regards, J |
Nokia N82 Keypad (?) error... - pressing = 1 = 10 and 0 = 10 :( | felix1986 | Nokia Hardware & Hardware Repair | 10 | 02-25-2012 14:35 |
6280 the key is not pressed | hidayetsimsek | Nokia Hardware & Hardware Repair | 1 | 06-21-2009 16:52 |
nokia 6101 via code is it possible | stanic | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 08-10-2005 07:08 |
6610i keypad light is always on | mohammedkabeer | Nokia Hardware & Hardware Repair | 4 | 07-05-2005 08:11 |
hlp plz nokia 6610 screen light is always on !! | wissamkoko | Nokia Hardware & Hardware Repair | 1 | 04-01-2004 09:15 |
