Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 10-29-2007, 23:31   #1 (permalink)
Member: 177088
Nokia 6111 Dead After Changing Lcd
Hi...have a 6111 which was working except it had a cracked LCD. So the LCD was changed and now the phone is dead. It won't even charge. None of the parts have been accidently damaged.
Anyone know why this is? Thanks
Old 10-29-2007, 23:32   #2 (permalink)
Member: 145716
check ribbon is fitted correctly
Old 10-30-2007, 05:36   #3 (permalink)
neokia's Avatar
Member: 366974
try to disconnected flexible and charge that phone..
if led keypad on..
it must be flexible problem
Old 10-30-2007, 05:50   #4 (permalink)
Member: 465901
most brobably the small resistance beside the ribbon connector must be broken which looks like a small glass ic. remove it and make jumper one above and one down in the middle leave blank. it will solve your broblem. because from this resistance on/off track goes to on/off switch. your on/off track is broken. remove this glass resistance and make jumper as said above
The Following User Says Thank You to ZENITHMOBILE For This Useful Post:
Old 05-01-2008, 11:08   #5 (permalink)
Member: 332730
6111
can u send diagram of it?
Old 05-01-2008, 14:21   #6 (permalink)
shaheb_anl's Avatar
Member: 622382
Sonork: 100.1625873 ( shaheb )
frist cheek rebon ..............
6111 dead after changing flex cable yellowcom Nokia Hardware & Hardware-Repair Area 1 06-22-2009 10:47
1208 Dead After Changing Lcd sharpgsm Nokia Hardware & Hardware-Repair Area 8 07-15-2008 06:56
N70 dead after changing lcd driver east asia link Nokia Hardware & Hardware-Repair Area 4 02-21-2007 20:03
903 dead after changed LCD MUTUAL Sharp 0 03-08-2006 21:18
6310 dead after change LCD & keypad led acme-4 Nokia Digital Core Technology 4 ( DCT-4 ) 0 05-26-2002 21:55
Page generated in 0.26159 seconds with 11 queries
