12-18-2010, 08:01 | #17 (permalink) |
Junior Member Join Date: Jan 2008
Member: 678530 Status: Offline Thanks Meter: 1 | for lcd light 3 solutions 1 chck line to lcd conecter up 1st pinfrom right side to near charging ic ther 2 small ics (2nd ic from left) 1st pin from frm left 2 change charging ic 3 network section near to up voluem key there is one small ic black colour and coil change i 500000000000000000000000% ok yor light problem |
06-12-2011, 20:52 | #19 (permalink) |
Freak Poster Join Date: Feb 2006 Location: Get Closer with Mobile Age: 44
Member: 228358 Status: Offline Thanks Meter: 32 | Yes Write Blank PPM Place blank ppm file instead of MCU and flash MCU only. After that flash the phone with latest means 7.20 version. I got two phones with same problem solved by this method. |
Nokia 6120 white display problem | samar_prince | Nokia Hardware & Hardware Repair | 26 | 10-21-2013 03:42 |
6120 white display comes and switch off | coolgsm007 | Nokia Hardware & Hardware Repair | 5 | 05-07-2009 16:16 |
6120 white display | samar_prince | Nokia Hardware & Hardware Repair | 10 | 03-27-2009 10:39 |
6120 white display | samar_prince | Nokia Hardware & Hardware Repair | 0 | 11-28-2007 15:10 |
6120 white display | samar_prince | Nokia Hardware & Hardware Repair | 0 | 11-26-2007 19:40 |
