Nokia 6120c mic ways by ashad |
will test then prove you its working or not |
yes it works.. same as n73,, there is no mic ic,, it direct goes to avilma ic |
Yes this is working solution.Tested by me. |
bro how can apply this jumper b,cose i have 6120c this phone mic + point is break so how can apply this jumper |
thanks good.....................................luck |
. thanku....................... |
ashad bai 6120 always show insert sim card i change avilma and change avilama site ic but same power open insert sim card .2 ic change but not work .pls advice me pls |
:)D Very gd Alfa Workers???????? |
very gooood link way....... |
how can do this; remove ic, solder the point and resolder ic or completly remove the ic or what . any help plz im weak in hard !! |
1 Attachment(s) @mahbubalfa thanks for giving information but dear, for my problem i connect upper point and it is working , before i connect ur point but not working. @.:B-A-G:. dear don't need to remove ic, make heat and put thin wire down to ic straight on capictor head , this is easiest way to make jumper |
it is difficult but done |
