Nokia 6230 not charging Hi guyz i have this nok 6230 showing " not charging" when charger is plugged to it. any one with clue; pls help asap. thanx |
If you are sure that Batt and charger is ok, check then the FUSE. GreetZ |
Fuse , battery and charger are all ok. I've re-flashed phone but still no luck. |
your phone discharged current from .... try rise pins from charging unit to charging interface. try this now.. bestman. |
or try changing the charging diode :D |
bestman. |
please where will i get the fuse of the set any diagram to show it please |
buddy firat of all try with a new battery .many times in dct 4 |
thanks guyz i will change the charging diode and post reply |
sir plzzzzzzzzzzz send me dygram 6230i charging fuse |
http://img219.imageshack.us/img219/6...30charging.jpg http://img219.imageshack.us/img219/6...jpg/1/w333.png |
hi bro u try removing C100 and C101 one bye one if not ok change R100 47k. may be problem solve. |
what if the fuse is not showing continuity |
not work............. |
i alsoo chan these part but problim not solve |
