07-22-2009, 07:13 | #1 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Chinese Section Age: 37
Member: 594884 Status: Offline Thanks Meter: 1,553 | 1110, 1112, 1200, 1208, 1650 new problem solved!!! The solution is for 1110, 1110i and 1112 Just change its battery connector The solution is for 1200, 1208, 1650 Just change its charging jack 100% at 100 times tested solution! BR .::skybird::. |
The Following 39 Users Say Thank You to .::skybird::. For This Useful Post: |
08-03-2009, 06:04 | #5 (permalink) | |
Cheater -Don't Deal with him- Join Date: Apr 2006 Age: 36
Member: 265129 Status: Offline Thanks Meter: 281 | Quote:
No man Its Only this problome Please Remove it Its Working. | |
The Following 8 Users Say Thank You to faizanbhatti94 For This Useful Post: |
08-25-2009, 09:52 | #9 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Hafizabad, Pakistan
Member: 269126 Status: Offline Sonork: 100.1616382 Thanks Meter: 370 | <a href="http://www.4shared.com/file/127541414/40928032/1200_not_charging_n_not_on_with_bettery.html" target=_blank><img src="http://dc150.4shared.com/img/127541414/40928032/1200_not_charging_n_not_on_with_bettery.JPG" border="0"></a> |
The Following User Says Thank You to malikasim For This Useful Post: |
08-25-2009, 18:53 | #12 (permalink) |
Freak Poster Join Date: Sep 2008 Location: uzbekistan Age: 40
Member: 860623 Status: Offline Thanks Meter: 65 | For changing charger connector on 1200 1208 1650 must be reason. Every time if i have phone which don't power with battery offen in charging connector may be water damaged. |
Nokia 1200 1208 1650 new sim ic solution100%ok? | rubel_chk007 | Nokia Hardware & Hardware Repair | 22 | 06-15-2010 19:03 |
1200,1208,1650 Charging Problem 10000% solve | abdurrahimsagar | Nokia Hardware & Hardware Repair | 0 | 01-27-2010 06:49 |
