09-23-2013, 15:35 | #1 (permalink) |
Freak Poster Join Date: Mar 2012 Location: Bihar
Member: 1741396 Status: Offline Sonork: 100.1640320 Thanks Meter: 16 | Nokia 6233 Fbush track Please Help, I need Nokia 6233 Fbush pinout Full Track Jumper with picture Because I hope some track is damage I am facing a problem in flashing HERE IS LOG Flashing Speed: 5.00 Mhz 16:12:43 : Processing : rm123_145_30005.600.mcusw 16:12:43 : Total blocks to write : 1062 16:12:43 : ================================================ 16:12:43 : FBUS Cable RX2 PIN Diagnostics 16:12:43 : ================================================ 16:12:43 : STATUS_REQUEST_BB5... 16:12:43 : 1 Sub Block ID : 16 PROGRAMMING_ERROR_BB5 16:12:43 : Block Length : 0F 16:12:43 : BB ASIC Index : 00 16:12:43 : Error Type : 05 16:12:43 : Error Spec : 08 16:12:43 : Of*****ng Address : 00000400 16:12:43 : Expected Content : 0000BC3F 16:12:43 : Detected Content : 0000BC00 16:12:43 : 16:12:43 : Reconnect your Cable Properly because RX2 PIN 16:12:43 : is NOT getting any DATA from the Box!!! 16:12:43 : ================================================ 16:12:43 : ERROR: RX2 PIN is NOT CONNECTED PROPERLY !!! 16:12:43 : ================================================ 16:12:43 : Flashing FAILED 16:12:43 : BB5_WRITE_FlashFile_0 16:12:43 : Go to Settings --> 16:12:43 : Nokia Settings --> 16:12:43 : FBUS DDR&2TX Synchronization Timeout 16:12:43 : Change the current value selected to a higher value 16:12:43 : and Restart AdvanceBox.exe software to apply it 16:12:43 : Operations Failed.... I am allways change flashing cable when flashing with only open PCB than also same problem,Cable Pin & pcb board connected properly pls pls pls help me |
