Old 05-28-2006, 03:39   #1 (permalink)
Member: 43368
Sonork: 100.1584138
Thanks Meter: 200
Nokia 6270 No Network & Restart Problem
Hi All,
NOKIA 6270 NO NETWORK & RESTART PROBLEM. I FLASH THE PHONE, FORMAT USER AREA, SET FAC. DEFAULT BUT SAME PROBLEM. HOW TO SOLVE THE PROBLEM.
HELP PLEASE.
THANKS.
Old 05-28-2006, 08:23   #2 (permalink)
..::Mr999::..'s Avatar
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
is imei ok???
check and see if imei is not crupted
Old 05-28-2006, 17:08   #3 (permalink)
medo2004's Avatar
Member: 78359
Thanks Meter: 61
u need pm and every think must be ok ................
Old 06-02-2006, 21:06   #4 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
I exactly have the same problem. i tried flashing and still the same.
Where can i find good PM file to try it before i start hardware work.
Old 06-03-2006, 04:44   #5 (permalink)
Member: 154749
Sonork: 100.92483
Thanks Meter: 1,048
before writing imei..on any BB5..just make a search and see result ..
Old 06-03-2006, 10:29   #6 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
Hey Guys, Good news
It was hardware problem, first i flashed the phone and write PM file but still the same.
Then i removed the Network IC which is located next to PA. I reball it and put it back so phone has now full network and it's not restarting anymore.
The Following 2 Users Say Thank You to cellularry For This Useful Post:
Old 06-06-2006, 13:20   #7 (permalink)
SIXTUS's Avatar
Member: 69727
Thanks Meter: 49
can you post the pix of the particular ic you removed, and how u reball it;that will of good help
best regard
sixtus
Old 06-11-2006, 09:10   #8 (permalink)
Member: 227262
but how come so many new 6270 got same problem of network and restart ??? company should provide a solution of it .
Old 06-18-2006, 17:58   #9 (permalink)
Member: 259008
Thanks Meter: 4
6270 no network
i have 3 6270 having the same problem also !
Old 06-18-2006, 21:17   #10 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
Guys it's so easy, i already repaired 3 peices.
All what you have to do is to rehot the network IC. post me a picture for 6270 and i will mark the ic for you. i don't have a picture for that board.
Old 07-17-2006, 17:00   #11 (permalink)
Member: 259008
Thanks Meter: 4
i got the picture
i got the picture of the 6270 broad
please show me the where the network IC at !
THX
The Following User Says Thank You to jmslnet For This Useful Post:
Old 07-18-2006, 09:58   #12 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
THX
Here is the solution. It's tested on more then 10 phones. all are working now.
Good luck.
The Following 3 Users Say Thank You to cellularry For This Useful Post:
Old 07-18-2006, 11:16   #13 (permalink)
Member: 313790
network problem & restart.
Originally Posted by haider
Hi All,
HELP PLEASE.
THANKS.
pls i want to know how i can repire this particular problem.
Thanks.
Old 07-18-2006, 18:03   #14 (permalink)
Member: 259008
Thanks Meter: 4
Good luck.
i got 3 nokia 6270 having the same problem which is no network. but after rehot the network IC. there is one 6270 are good with the solution , other 2 phone are still the same no network. i have been tried rehot those 2 phone more than 3 times and it is still the same
Old 07-19-2006, 07:16   #15 (permalink)
Registered User
Member: 83237
Sonork: 100.1577738
Thanks Meter: 61
not work
Good luck.
6270 network if you rehot and reball ic your network working properly but after few days same problem so please dont wst your time for thish temporary solution better replace new ic and write pm....
thank you
nokia 6270 no network please help me work in airtel but no work aircel prakash40 Nokia Hardware & Hardware Repair 0 02-04-2010 06:24
Nokia 6270 No Network Solution anowar_47 Nokia Hardware & Hardware Repair 25 02-02-2010 16:29
6680 No Network & restart need help! T Mobile Nokia Hardware & Hardware Repair 2 12-30-2007 16:27
nokia 6270 no network danish_teli Nokia Hardware & Hardware Repair 4 06-30-2007 19:22
Nokia 6270 no network and restart problem haider Nokia Hardware & Hardware Repair 1 07-12-2006 16:25
Page generated in 0.25958 seconds with 10 queries
