nokia 6280 charger not supported hi to all, i have nokia 6280 with (charger not supported) problem. i cleen the bord of phone. and write pm file but still same. any body have any slution for my problem? |
Mostly it's TAHVO IC problem; try first to reflow it, if problem persists then replace it, G.O.D assist ... |
Man, how can i give another solution & the mentioned one is the left reason after you did cleaned board & written PM file !!! It's not a puzzle game !!! |
We may try again: 1- Try another trusted genuine battery. 2- Try another trusted genuine charger. 3- If RETU IC is not under-filled try yo reflow it, if not works then replace it. 4- No way but to try replacing TAHVO IC even if it's under-filled (if you really want to solve the problem) ;) . P.S: I'm not convinced with step 3 at all but it's just a try since TAVO IC is pasted. G.O.D assist ... |
I think that you need to reballing RETU IC with or without glue under it. |
i just deep heat tahvo in 6125 and problem solved. tahvo in 6125 is not glued. Kind regards, Vicky |
i also got the same problem in 5300,chnged the batt,charger,replaced 2 TAVO ic still in the same spot. so guys what do u thing it is? |
maybe ur bsi line short to ground!! try to remove the resistor in bsi line.... |
ReHoT TAHVO N2300 Quote:
;):D |
