Old 11-28-2006, 16:51   #1 (permalink)
miecom's Avatar
Member: 113818
Thanks Meter: 29
Nokia 6280 Lcd Problem
Anybody Can Help Me Solve The Problem For Nokia 6280.my Problem The Lcd Not Display(blank) But Lcd Light And Keypad Light Ok.
I Try:
1.change Lcd
2.change Flat Cable
3.change Keypad Board
4.flash Latest Virsion
But
Still Same Problem,and
Anyone Can Show Me Which One Display Keypad Ic
Please Help....
Old 11-28-2006, 17:38   #2 (permalink)
Member: 44189
Thanks Meter: 24
thkx for sharing
br..........
midooo
Old 11-28-2006, 18:39   #3 (permalink)
Member: 320354
Thanks Meter: 48
Try This
Good Luck man
Old 11-28-2006, 21:29   #4 (permalink)
miecom's Avatar
Member: 113818
Thanks Meter: 29
I Try My Best
Thanks So Much For Support.
Old 12-19-2006, 12:23   #5 (permalink)
Member: 144041
i changed Keypad Board and i get the light
try to change it good luck
Old 01-31-2007, 22:31   #6 (permalink)
Member: 299762
thanks solution worke'd 100%
Old 02-01-2007, 00:18   #7 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
Originally Posted by Jeffyoh88 View Post
Try This
Good Luck man
watdou mean same as keypad ic,u mean in place of these ic,we use keypad filters also?plz correct if i m wrong?
Old 02-12-2007, 22:10   #8 (permalink)
Member: 21937
Thanks Meter: 279
hi
i got 6280 , black lcd , phone is working other then that.
i have this small black IC burned for some reason , i have removed it , still same problem , i have changed it from 6230 (same ic ? near mmc socket)
problem is the same.
is this my problem , or those other 2 glass IC's ?
thx
The Following User Says Thank You to TRABEL For This Useful Post:
Old 02-17-2007, 21:45   #9 (permalink)
Member: 21937
Thanks Meter: 279
changed the black IC lcd is working again
Old 02-28-2007, 06:07   #10 (permalink)
Member: 33029
Thanks Meter: 9
I can't get this black Ic can I replace it from 6630 glass ic near keypad connector or use jumper?Thanks in advance.
Sorry for my curiousity this ic is N6050 LP3987ITLX-2.85-NOPB power supply for FM radio,why it will effect lcd as well?
Old 02-28-2007, 07:10   #11 (permalink)
Member: 21937
Thanks Meter: 279
no jumper for this IC , all jumpers i tested give me phone not turning on.
you can take this IC from 6230 near mmc glass ic you will see this black ic.
good luck.
dont forget to replace flat cable lcd and keypad to be sure none of those is bad before replacing this ic
Old 03-01-2007, 12:19   #12 (permalink)
Member: 33029
Thanks Meter: 9
Thanks for your reply appreciate it very much.
Old 03-01-2007, 12:20   #13 (permalink)
Member: 33029
Thanks Meter: 9
Moderator Sorry for my double post,pls delete it.
Old 03-21-2007, 00:13   #14 (permalink)
Member: 283901
Cant Find Ic
i have tried finding the the black ic on 6230 but i cant. can you give me the code for the ic so i can replace it with the black ic on 6280
Old 05-24-2007, 16:30   #15 (permalink)
salim_belka2002's Avatar
Member: 64587
Thanks Meter: 39
i ve tried to change the IC littel crystal near the camera for the camera fault now i ve a blank screen on my 6280
please is it the fault
or mybe i ve overheated the board
where s the probleme
please my customer is angry help me
nokia 6280 lcd problem. plz hlp peter002 Nokia Hardware & Hardware Repair 11 01-13-2010 21:43
Nokia 6280 LCD Paul Hilton Wanted Products 4 03-18-2008 01:37
Nokia 6280 lcd ahmadz Wanted Products 11 03-14-2008 00:07
nokia 6280 lcd wanted garcea10ro Wanted Products 10 09-05-2007 10:06
Nokia 6280 Lcd Problem miecom Nokia Base Band 5 ( BB-5 ) 0 11-28-2006 15:16
Page generated in 0.25000 seconds with 10 queries
