Old 11-30-2007, 21:54   #1 (permalink)
Member: 470292
Thanks Meter: 147
Nokia 6288 Dead Help......
I have Nokia 6288. It was locked to 3 network. I unlocked it through testpoints. It was done successfully. It was working well. Incomming outgoing calls etc. After 2 days phone is now dead by himself. Its battery terminals are fully short. Which Ic or component should be short. Please help...........
Old 11-30-2007, 21:59   #2 (permalink)
Boshko_Alfa's Avatar
Member: 472933
Sonork: 100.1590967
Thanks Meter: 1,331
try ti flash? easist way to fix-it is the Hammer sollution by Legija. No Hard feelengs
The Following User Says Thank You to Boshko_Alfa For This Useful Post:
Old 11-30-2007, 22:54   #3 (permalink)
Member: 470292
Thanks Meter: 147
Thanks that is your job. You are discouraging people.
I need some possitive hants
Old 12-01-2007, 06:53   #4 (permalink)
gokul2005's Avatar
Member: 169384
Thanks Meter: 110
Maybe PA was short...remove this coil an check...
Old 12-01-2007, 06:59   #5 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
touch ic! if u touch ic or regulator very hot should the ic or regulator short!!!
Old 12-01-2007, 07:04   #6 (permalink)
Member: 278058
Thanks Meter: 81
Connect power supply to positive and negative terminals of the phone and look what part is getting hot. Remove that component.
Old 12-01-2007, 07:35   #7 (permalink)
acay's Avatar
Member: 197916
Thanks Meter: 157
yes..find ic or komponen is getting hot, and remove it!!!
Old 01-31-2008, 18:09   #8 (permalink)
Member: 299902
Thanks Meter: 20
l have 6288 which would not go off l opend the phone and cleaned it now it will not go on flashed,changed flax, lcd. top board with no results the phone powers on with fbus cable and works fine but will not with battery
Nokia 6288 Urgent Help Needed pjjikar Nokia Base Band 5 ( BB-5 ) 4 09-09-2008 15:35
ODIA NEDD HELP !!! Nokia 6288 DEAD After Flash !!!! Unlocker_001 HWK 1 02-21-2008 11:47
nokia 6600 dead help me please sanchitmahajan WD2 & APE (Symbian Phones) 3 02-10-2005 17:13
Page generated in 0.15818 seconds with 10 queries
