Old 10-11-2007, 20:58   #1 (permalink)
Member: 579284
Thanks Meter: 6
NOKIA 6300 battery drain problem
I have NOKIA 6300 which drain battery very fast.When i insert a fully charged battery the battery empty while it is switch off condition .And the problem is not battery.Help......???????
Old 10-15-2007, 18:08   #2 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
Try to change PA and post the results.
Old 10-16-2007, 04:43   #3 (permalink)
Member: 473823
Thanks Meter: 10
there is short in the circuit of charging
Old 10-16-2007, 09:33   #4 (permalink)
Member: 171140
Thanks Meter: 22
When contacted there are heated or not measuring your reluctance before any step to indicate whether there is impeded Trend
Old 10-16-2007, 17:16   #5 (permalink)
Member: 390195
Thanks Meter: 17
give the heat to PA and chaack battery conector re sold
Old 05-29-2009, 08:53   #6 (permalink)
Member: 1037405
6300 battery empty
i have 100% solution tested me many times.........mail me [email protected]
Old 05-29-2009, 09:06   #7 (permalink)
Member: 496694
Thanks Meter: 30
bro you better give us your solution.because it is difficult send each other by email.
Old 05-30-2009, 08:27   #8 (permalink)
Member: 1037405
6300 battery empty
ok dear bro........just remove the fuse & short it, ur problem will b solved.....
Old 05-30-2009, 08:31   #9 (permalink)
ira balisi's Avatar
Member: 316429
Thanks Meter: 80
did u check the phone maybe it's shorted?
if yes, check the capasitors if there's a lick or burn
Old 05-10-2010, 16:32   #10 (permalink)
Member: 1300573
nokia 6280 battery drain fast samanthe Nokia Hardware & Hardware Repair 6 03-17-2011 09:45
k800i battery draining problem krimsas Sony Ericsson Hardware Repair 0 02-28-2009 15:40
P990i battery drain problem cerbu Sony Ericsson 1 09-13-2008 08:19
6111 battery drain problem. manyosa Nokia Hardware & Hardware Repair 2 09-11-2007 23:36
N70 ,battery drain problem ahmed Nokia Hardware & Hardware Repair 1 10-01-2006 01:04
Page generated in 0.37284 seconds with 8 queries
