Old 12-21-2007, 12:58   #1 (permalink)
Member: 466060
Thanks Meter: 4
Nokia 6300 charging
I have nokia 6300 but the problem is that the phone is not charging, plz any solution.
The Following User Says Thank You to dons005 For This Useful Post:
Old 12-21-2007, 13:14   #2 (permalink)
linekbp's Avatar
Member: 81697
Thanks Meter: 149
does it show charger not supported or does not show charging at all?
The Following User Says Thank You to linekbp For This Useful Post:
Old 12-21-2007, 13:17   #3 (permalink)
Member: 278058
Thanks Meter: 81
solutions already posted, plz search
Old 12-21-2007, 13:22   #4 (permalink)
Member: 466060
Thanks Meter: 4
shows notting
Bros,
Is not showing any thing at all.
Old 12-21-2007, 14:18   #5 (permalink)
Member: 88831
chek the charging path and TAVHO power IC
Old 12-21-2007, 14:35   #6 (permalink)
swapnilbombay's Avatar
Member: 268495
Thanks Meter: 27
tell in brief what exact the screen indicate :-not charging or reconnect charger or charger not getting sence
1}first check the charger
2}charging socket
3}fuse ,diode & r, etc
than also if its not working than flash the phone with the latest version.
post if not solved
good luck
The Following 2 Users Say Thank You to swapnilbombay For This Useful Post:
Old 01-11-2008, 03:58   #7 (permalink)
Member: 442579
Thanks Meter: 9
remove c2071 okie man
Old 10-14-2008, 10:00   #8 (permalink)
Member: 528183
Thanks Meter: 7
charging indication is ok but have not charge plz help
Old 10-14-2008, 10:03   #9 (permalink)
pupaji's Avatar
Member: 734871
Thanks Meter: 1,348
check the charging interface first then change thahvo.
Old 10-11-2009, 14:51   #10 (permalink)
Member: 416620
Thanks Meter: 5
6300 nokia charger not supported plz any solution
Old 10-11-2009, 17:59   #11 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try it..........
The Following 5 Users Say Thank You to mahbubalfa For This Useful Post:
Old 10-11-2009, 22:50   #12 (permalink)
Member: 1080341
Sonork: king
n95 8gb
Hi
hello friends i had n95 8gb it has a camera prb!when i open camera it automatically goes to menu plz help me
Old 01-13-2010, 13:15   #13 (permalink)
Member: 181815
change patta and cheak your problem short out
Old 01-13-2010, 15:30   #14 (permalink)
shivashakthi's Avatar
Member: 594753
Sonork: 100.1605626
Thanks Meter: 822
http://forum.gsmhosting.com/vbb/showthread.php?t=598972
The Following User Says Thank You to shivashakthi For This Useful Post:
Old 10-04-2010, 07:58   #15 (permalink)
Member: 1263622
Thanks Meter: 149
hi bro, my 6300 not show charge.charger ok but no charge in phone. ple, argent solution
The Following User Says Thank You to Rotan Sarkar For This Useful Post:
lg kg 270 charging solotion with nokia 6300 charging jeck Guljee guljee786 LG Hardware Repair 0 03-02-2009 08:04
lg kg 270 charging solotion with nokia 6300 charging jeck Guljee guljee786 LG Hardware Repair 11 03-02-2009 07:08
nokia 6300 charging /\/\A/\/| Nokia Hardware & Hardware Repair 5 12-12-2008 10:55
Nokia 6300 charging ahmad bashir Nokia Hardware & Hardware Repair 5 11-20-2008 10:36
nokia 6300 charging ok but no power on qayyoom1 Nokia Hardware & Hardware Repair 12 06-01-2008 12:03
Page generated in 0.25708 seconds with 9 queries
