nokia 6300 dead ::: Please Help i have a nokia 6300 which is dead , when i try to power on the set , only the side lights glow and nothing happens to the phone .. when i try to flash the phone then also only the side lights glow ... When i Click on CHK come this Booting phone... Error sync the phone... and when ic click on inf come this FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Switching to serial... Powering the phone... Failed! Aborting! what should i do ? please help .. thanks aliraqi |
first check ur phone in hardware.............:) |
Hardware i thing is ok have you my be any anther idea to chick the Hardware :confused: |
is ur phone is water dameged , or drop by costmer, or this problem come without any of these two problem........ |
The phone is water dameged |
1.clean ur pcb properly and check or repair the area which is damaged by water ........... check and post result....... |
I don't see any file selected by U. :confused: |
Booting phone... ur 6300 rap3gsm can't booting cek vcore =1,4v if vcore not present change tahvo or make jumper to vio |
But Check The Voltage From RETU Too Then Check The Thavo Voltage ( Vcore ) Go To >> ( Rap3G ) When One Of The Voltages Are missing Ten You Make A Jumper With The Same Voltage ! If The Voltage Of RETU Is Ok And The ( Vcore ) Missing . Make Jumper From VIO . |
nice can you please show me with photo the jumper way PLEASE:( |
Try rehot Tahvo(N2300) , it work for me . Good luck ! |
What Voltage Is Missing ? Tell Me So i Can Show You Its Jumper :D |
Hello! Have a same problem. Nokia 6300 after water. Not present VCORE. :( RETU, TAHVO, AHNE, RAP, Flash - All is IC is reball. TAHVO is changed. JAF CHK log: Booting phone... CMT Boot Data: Asic ID: 000000010000022600010006010C192101001101 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 2AC000015EC46F568449B8EC03B82545B14C6EE1 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 191EC665DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... Error loading cmt boot... Any have a solution? Thank you. |
this is ram ic problem or ur ram ic is in flash .....u have to change it...... |
Just U Reheat The Retu Ic,,, The Retu Ic Is Apower On X.......because The Phone Is From Liquid Damage Thats All!!!! |
