nokia 6300 keypad solution i have nokia 6300 which none keypad don't work. Please can i do? |
you must change ic keypad |
change ic keypad.................... |
Where is ic keypad on the board? thanks |
ic keypad change it enjoy |
ic is next to the simreader the glass ic its the same as 3110classic keypad ic. |
nokia 6300 keypad solution 3 Attachment(s) ;););)nokia 6300 keypad solution;););) |
i changed the keypad ic but still the keys are not working i think its another problem pls help! the problem starts after phone was drop and hit the ground,i need your help very urgent pls! |
i change keypad ic any key not press what is the solution please help |
i chnge keypad ic more then five pls give perfect solution |
brother, 1. change keypad ic 2. remove side volume key up and down prob, still 3,then slow heat in cpu 4, problem still change cpu |
nokia 6300 no keypad ic solution by jumper??? |
