Old 11-14-2007, 19:06   #1 (permalink)
Member: 606801
Thanks Meter: 8
nokia 6300 no network
no network what i have to do?(flash or hardawre)
note:i m a beginner
Old 11-14-2007, 19:35   #2 (permalink)
Member: 77768
Thanks Meter: 70
Wink No it is harware problem
Dear
it is hardware problem heat Antenna switch,Tranmiter, and Hager ic of your mobile hope you will get solution otherwise you have to change the hager ic.
let me know in detail signal come once when you restart your mobile or not.pm me as i could write you the solution.
kashif
Old 11-15-2007, 16:57   #3 (permalink)
chandy pok's Avatar
Member: 447590
Thanks Meter: 378
6300 no svc
Take a look my solution & post result.
The Following 12 Users Say Thank You to chandy pok For This Useful Post:
Old 11-15-2007, 17:28   #4 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
gurbuz '
No network can be cause, if you live under a thin building or under a long story building.
simple tip.
1. try reboot your mobile phone twice and watch the search for Network.
2. if not, try another battery and reboot again, as i early told you.
Note: No Network is an hardware problem
please, do not flash your phone.
if not successful, post me a mail.
bestman
The Following User Says Thank You to bestman For This Useful Post:
Old 11-15-2007, 17:37   #5 (permalink)
GSMLover2010's Avatar
Member: 52956
Thanks Meter: 49
good share!!!!!!!!!!!!!!
The Following User Says Thank You to GSMLover2010 For This Useful Post:
Old 11-16-2007, 18:56   #6 (permalink)
Member: 606801
Thanks Meter: 8
net work okkkkk 6300
i just heated and it s ok right now thanks a lot...§§§§§§§§§§ i changed nothing....!!!!!!!!!
Old 03-04-2008, 11:45   #7 (permalink)
Member: 300795
Thanks Meter: 7
For me work perfekt! Thanks a lot!
Old 03-31-2008, 15:50   #8 (permalink)
Member: 146708
Sonork: 100.108221
Thanks Meter: 1,595
hi all...
i have the same pb.. no network on 6300..but when i have search it manually operators are exist... but not accesing..
what is the pb..?
phone is water damaged..
Old 04-03-2008, 18:33   #9 (permalink)
techouse's Avatar
Member: 155454
Thanks Meter: 18
try to change n7520
Old 04-07-2008, 14:09   #10 (permalink)
Member: 300795
Thanks Meter: 7
Rehot power IC and signal procesor IC. I made many of 6300.
Old 04-11-2008, 18:35   #11 (permalink)
Member: 362582
Thanks Meter: 55
sir my 6300 water damage set ok but network vary some time no net work plz help me
Old 04-13-2008, 03:51   #12 (permalink)
zahed1978's Avatar
Member: 444785
Thanks Meter: 170
thk for the good solution
Old 07-08-2008, 07:29   #13 (permalink)
sharpgsm's Avatar
Member: 313652
Sonork: 100.1625717
Thanks Meter: 99
good work sir thanx a lot
Old 07-09-2008, 11:52   #14 (permalink)
shok9992000@yah's Avatar
Member: 578941
Thanks Meter: 108
in my case 6300 no network , when i tried to serch network manually the restarts i think this may be a flash problem. Am i right
Old 10-16-2008, 13:39   #15 (permalink)
shakkeermp's Avatar
Member: 871211
Sonork: 808888
Thanks Meter: 36
try to change Helga 10000%%% ok
plz help me 6300 no network illu Nokia Hardware & Hardware Repair 4 05-02-2010 09:18
nokia 6300 no network.......... Teepat Nokia Hardware & Hardware Repair 4 12-10-2009 16:49
6300 no network imran_panipat Nokia Hardware & Hardware Repair 3 06-15-2008 10:33
6300 no network after unlocking tr3pplea MT-BOX 2 05-20-2008 15:25
Nokia 6300 no network Bloedman Nokia Hardware & Hardware Repair 0 05-04-2008 10:36
Page generated in 0.50494 seconds with 9 queries
