nokia 6303 always battery low.... hello m8,i av nokia 6303,immediately i power it on,it shows nokia and says battery low,after that it shows white screen. what can i do to make it work........m8 ?? thankx. |
did you try another battery sir?have you test if theres a leak in your phone?hope it helps |
brother cheak any parts may be short. |
@ fengyo. Code: have you test if theres a leak in your phone? any other idea ?????? |
brother see shortage in ur set also see its water damg and check pa..... Guljee:) |
cheak betty ic bro .......... |
damg pa and check........................ |
i have nokia 6260s-1 have same problem show nokia logo and battery low and then white screen. any one know where to start. |
brother set me sorting hai power ic and chargng ic reboll ya chang 1000000%solve your proble |
6303 show battery low when calling. when calling 6303 show battery lowand switched off.any pm problem? |
Check the battery connector properly than check bsi line,on most of the sets i have seen battery connector disconnected from board what i do is make jumper from bsi connector to condesor near battery connector |
gentleman this is right solutio for your mobile http://forum.gsmhosting.com/vbb/f148...ution-1044743/ thanks to you all by gsmzaman |
and my battery connector damage under the battery connector tracks damage and now no work camera and bluetooth... any solution? |
