10-12-2013, 14:12 | #1 (permalink) |
Insane Poster Join Date: Oct 2008
Member: 876640 Status: Offline Sonork: [email protected] Thanks Meter: 5 | Nokia 6303c rm443 flashing problem MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C085414D Using device: USB ROM and HTI, FW ver: 00.50, SN: 0101426D Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Processing MCU file: rm443__10.12.mcusw [BB5,BB5 ALGORITHM] size: 24.67 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 270001086FA27D569D730E2BE1B2D82AEE7C9FF3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x69180 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x77780 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 1D716603 Verifying communication to device OK. Erase size: 28.25 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.889 s CMT FLASH,NOR area [00040000-0005FFFF] erased in 0.655 s CMT FLASH,NOR area [00060000-0007FFFF] erased in 0.546 s CMT FLASH,NOR area [00080000-0015FFFF] erased in 3.900 s CMT FLASH,NOR area [00160000-0023FFFF] erased in 4.165 s CMT FLASH,NOR area [01740000-0191FFFF] erased in 9.329 s CMT FLASH,NOR area [00240000-0173FFFF] erased in 1 min 44.942 s CMT FLASH,NOR area [022E0000-0261FFFF] erased in 16.255 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: E8E6E2AB [RAP Certificate 140 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT ISA+DYNSW block sent Programming completed in 1 min 36.728 s Processing PPM file: rm443__10.12.ppm_i [BB5,BB5 ALGORITHM] size: 6.70 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 9.75 MB CMT FLASH,NOR area [01920000-022DFFFF] erased in 48.438 s Flash programming ... Programming completed in 26.479 s Processing CNT file: rm443__10.12.image_i_ru_silverbrown [BB5,BB5 ALGORITHM] page size: 128 K size: 10.26 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Erase size: 25.62 MB CMT FLASH,NOR area [02620000-029BFFFF] erased in 22.683 s CMT FLASH,NOR area [029C0000-03FBFFFF] erased in 2 min 22.116 s Flash programming ... Programming completed in 41.778 s Total time for flashing process(boot+erase+write) was 9 min 33.317 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6303 classic USB Phonet, PORT_ID: 3749CA Verifying communication to device OK. Phone type: RM-443 (Nokia 6303 classic) SW version: V 10.12 08-04-10 RM-443 (c) Nokia Imei plain: 35319903441618-3 Product code: 0569445 Battery voltage: 3981 mV, current: 89 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) RPL saved to "C:\mobileEx\3.5\data\backup\BB5_RM-443_353199034416183_12_10_13_175512_SIM.RPL" SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Market items is empty, please select the correct products path ! pleas help me what i do it.or its rpl is damage thanks in advancd |
