12-19-2003, 02:58 | #1 (permalink) |
Insane Poster Join Date: Nov 2003 Location: +96653657566
Member: 44366 Status: Offline Thanks Meter: 1 | Nokia 6310i is my last repair for hardware !!! just during the first minute the battery become low and the turn off the phone. By the way I replaced a new battery. I asked a friend about that problem, he told that I have to remove and reinstall the PF because that maybe due to the PF consume the battery. Then I did what he told me but now ( NO network ) at all. and some of the small capacitors and resistors around the PF moved and I think that I returned them back in them places but not sure exactly. So what I should do now? someone will say replace the PF and then will see!! For your info that PF isn't available in the market . I'm very sorry that I made this story and make all of you read it, but I need your help and advises. |
12-19-2003, 03:11 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @2h@ard PF ?????? You mean PA !!! PA = Power Amplifier. You can replace with PA from 3310 = 8109B or 10R Only thing is that you loose 1900 Mhz, nothing else, so if you are not in the states it wont matter !! Regards |
12-20-2003, 23:24 | #4 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | cool hawk is right 100% but check also the line bsi and v bat to pa pf is common in egypt and arab world in stead of pa wonder where r u from ????? |
12-21-2003, 01:16 | #6 (permalink) |
Member: 7751 Status: Offline Thanks Meter: 74 | @2h@ard Heres the reason : As you see both 8109B and 10R is on this PA for 3310 !!! Some other PA's also have the marking "10U" or "32U" but the correct name for them is PFO8109B, some folks just say the othger number to add to the confusion Regading the PA from 3310 to 6310i, as I wrote before, 6310i is a triband phone supporting 900-1800 and 1900 MHZ, by replacing the original PA in 6310i against a PA from 3310 means only that you'll loose the 1900 MHZ band, since the original 6310i PA is triband !!! But who cares we are not in the states anyway !!!! Regards |
12-22-2003, 22:01 | #9 (permalink) | |
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
don't press the pa while you solder it just adjust it and solder it bythe hot air if you press it it might short the ground and the phone become dead due to this short | |
12-23-2003, 00:20 | #10 (permalink) |
Member: 44366 Status: Offline Thanks Meter: 1 | GSM Coolhawk raheeb thank u very much but i need now to rturn the small resistors and capicitors to their original places. i have the picture of the 6310i board but it is not very clear. can help me to get a clear view to this board? again gr8 thnx |
today is the last day for you | mizocenter | MSS Box II | 0 | 12-25-2009 04:42 |
>>> Sigma this is my last Warning!!!<<< | gsmplaza9908 | The Market Feed Back | 1 | 04-03-2008 16:58 |
Just MY LAST post for gsmhosting ! | ..::hotlovercool4::.. | Off Topic Zone | 120 | 10-31-2007 13:59 |
What is the last update for old Martech1 ??? | dragosgsm | SIEM Service Tools | 1 | 10-11-2007 11:57 |
This is my last thread as moderator. | Platijet | Off Topic Zone | 43 | 11-21-2006 14:24 |
