Old 07-03-2005, 17:06   #1 (permalink)
Member: 70514
Thanks Meter: 10
Nokia 6310i strange screen problem
Hello,
a customer gave a 6310i to me, which has a very strange display problem:
As soon as you switch it on it displays "Insert SIM". After 3-4 seconds the screen begins to flicker and shows horizontal lines flickering very fast. As soon as you press a button, the screen appears again.
Also, if you hold a button (eg. the red button), the screen remains correct ("Insert SIM") but about every second periodically 1 horizontal line blinks on the screen. As soon as you release the button again - immediately the flickering of those many horizontal lines begins again.
I updated the firmware, I changed the display and measured display ways - Everything fine - except under the UPP i cant measure.
Please help.
Thanks, Jan.
Old 07-03-2005, 18:24   #2 (permalink)
Member: 9254
Thanks Meter: 4
Hi Jan
Replace capacitor C302,C303 and C304.
B.R
M@RTY
Old 07-06-2005, 17:19   #3 (permalink)
Member: 70514
Thanks Meter: 10
Hi M@RTY,
thanks for your help!
Question: I removed C303, C304 because i wanted to replace them. Then i noticed that I dont have any PCB with these capacitors so i couldnt solder new ones in. Now i tested the device and it seems to be working well (the display fault is gone) without those two capacitors installed. Is there any possibility that i could damage the phone when i use it without C303 / 4 ?
Regards,
Jan
Old 05-29-2008, 07:28   #4 (permalink)
mohd aji's Avatar
Member: 202201
Thanks Meter: 21
bro i also have same problem and i also change capacitor C302,C303 and C304 but problem not solved
Old 05-29-2008, 08:37   #5 (permalink)
VIBINDAS_INDIA's Avatar
Member: 707582
Sonork: 100.1620432
Thanks Meter: 334
next related upp so rehot or replace upp good luck
Old 06-16-2008, 08:14   #6 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
thanks for sharing.....................
Nokia N81 8gb screen problem, artifacts and black screen.. DjDecibel Nokia Hardware & Hardware Repair 8 01-03-2011 18:15
nokia 6310i strange problem fani644 Nokia Hardware & Hardware Repair 0 04-14-2009 05:34
NOKIA 6310i - CAR KIT PROBLEM - IT SQUEALS!! sandrock2005 Nokia Hardware & Hardware Repair 6 03-09-2006 16:02
NOKIA 6310i DLR-3P problem manonfire Nokia Digital Core Technology 4 ( DCT-4 ) 1 04-04-2005 00:00
6310i strange signal problem gsm_style Nokia Hardware & Hardware Repair 5 10-13-2004 04:03
Page generated in 0.22841 seconds with 10 queries
