01-13-2009, 15:42 | #4 (permalink) |
No Life Poster Join Date: Sep 2007 Location: india
Member: 581178 Status: Offline Thanks Meter: 438 | first get on phone with sim card.then type *#2820# you will see bt adress of your phone. if bt adress is empty you have problem with bt module. 1- just change bt ic on bt module , it looks like 3310 flash ic but not same 2-still have same problem, then change other 2 ic on bt module 3-i have no time: change bt module the second type problem is with software or with mmc socket and mmc card. it is tested by me if bt adres is not empty then 1-full flashing+ui settings+format user area+rp bt 2-still have same problem then you check it without mmc card, then check mmc card socket ways. |
Nokia N95 BT and Wifi not working | pepik | Nokia Hardware & Hardware Repair | 10 | 11-17-2012 16:47 |
2112 ringar & spik & mic not work pizzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz z | punitdodiya | Nokia Hardware & Hardware Repair | 1 | 09-16-2009 13:48 |
6600 menu and camera not working | kprajeesh4u | Nokia Hardware & Hardware Repair | 6 | 05-26-2007 09:32 |
6600 changed BT twice but not work BT and not open gallery!!! | majidjony | WD2 & APE (Symbian Phones) | 7 | 09-10-2006 14:29 |
6600 *,#,c keys not working | 47eleven-t | Nokia Hardware & Hardware Repair | 5 | 01-18-2005 17:29 |
