Old 03-23-2009, 11:52   #1 (permalink)
Member: 195065
Thanks Meter: 11
nokia 6500-slide keypad problem
Please help repair keypad problem.Working only power buton on/off .With HWK SELF TEST ST_KEYBOARD_STUCK_TEST -failed.
The Following 2 Users Say Thank You to djems For This Useful Post:
Old 03-23-2009, 14:04   #2 (permalink)
Registered User
Member: 828691
Thanks Meter: 33
mr try clean or change flexibell keyboard n keypad ic
The Following 3 Users Say Thank You to xEDIx For This Useful Post:
Old 03-23-2009, 16:23   #3 (permalink)
Member: 641166
Thanks Meter: 331
hi
File Type: jpg c9953c695d779e025973aef71398aeb7[1].jpg (142.2 KB, 11774 views)
The Following 20 Users Say Thank You to galant2 For This Useful Post:
Old 03-23-2009, 16:25   #4 (permalink)
genci titi 2002's Avatar
Member: 193804
Sonork: 100.1684818
Thanks Meter: 1,693
change the keypad ic 6500 have 2 keypad ic
The Following 4 Users Say Thank You to genci titi 2002 For This Useful Post:
Old 05-23-2009, 14:20   #5 (permalink)
Member: 300361
Thanks Meter: 4
i have 6500s keypad not working 2.5.8.0 and left right.
The Following 4 Users Say Thank You to elnursoft1 For This Useful Post:
Old 06-06-2009, 11:11   #6 (permalink)
Member: 186423
Thanks Meter: 24
down key ic
if only work on-off button ,means: some keys going work-sticky, and you can try once : down keypad ic chancing.
The Following 2 Users Say Thank You to akifable For This Useful Post:
Old 06-06-2009, 11:22   #7 (permalink)
ace_venturia's Avatar
Member: 260236
Sonork: 100.1641081
Thanks Meter: 135
also check the volume key IC near the volume keys
i've found the ICs defective for keypad not work in 6500s
The Following 17 Users Say Thank You to ace_venturia For This Useful Post:
Old 08-30-2009, 16:15   #8 (permalink)
Member: 598721
Thanks Meter: 35
Hi. "ace_venturia" is right! In my case these two crystals were defective. Thanks
The Following 4 Users Say Thank You to Kruscher For This Useful Post:
Old 02-14-2010, 16:33   #9 (permalink)
Member: 1041698
Thanks Meter: 4
nokia 6500s volume key problem solution
The Following 3 Users Say Thank You to dulalsyl0077 For This Useful Post:
Old 02-24-2010, 11:40   #10 (permalink)
Member: 570252
Thanks Meter: 207
same problem here
only ON button is working and not powering off the mobile
both key pad IC's are changed
any help ????
The Following 2 Users Say Thank You to temp_temp For This Useful Post:
Old 03-02-2010, 20:22   #11 (permalink)
i am the master's Avatar
Member: 996052
Thanks Meter: 35
hello i have one 6500slide key pad problem i change the flex and i changed both key pad ic's but phone is still stock on start up phone without sim card and i can not select anything any solution for this thank you Rash
The Following 2 Users Say Thank You to i am the master For This Useful Post:
Old 03-02-2010, 20:24   #12 (permalink)
Member: 996052
Thanks Meter: 35
did you change the flex or not
Old 03-05-2010, 08:44   #13 (permalink)
Member: 195065
Thanks Meter: 11
Very thanks for all .Problem is flex cable.
Old 03-05-2010, 11:10   #14 (permalink)
dez com's Avatar
Member: 525901
Sonork: 100.1607503
Thanks Meter: 47
hello i have the display problem change the flex cable still samproblem need chema for display ic 6500S slid
Old 04-30-2010, 07:41   #15 (permalink)
Member: 169323
Thanks Meter: 28
Change both keypad ic..........if not ok,then check circuit...
nokia 6500s-1 keypad problem nkakanou Nokia Hardware & Hardware Repair 4 06-20-2012 08:33
Nokia 6500 slide keypad (*,0,#) Not working Unique_ah Nokia Hardware & Hardware Repair 8 08-10-2011 17:49
6500 slide keypad problem lijgeorge Nokia Hardware & Hardware Repair 13 04-27-2010 07:36
6500 slide keypad problem lijgeorge Nokia Hardware & Hardware Repair 4 02-07-2009 06:59
Page generated in 0.25943 seconds with 11 queries
