Old 05-30-2010, 08:45   #16 (permalink)
Member: 264290
Thanks Meter: 46
remove volume ic near volume keys 1000% working solution
Old 05-30-2010, 08:58   #17 (permalink)
Member: 890546
Thanks Meter: 9
change the keypad ic 6500 have 2 keypad ic
Old 06-11-2010, 20:21   #18 (permalink)
i am the master's Avatar
Member: 996052
Thanks Meter: 35
volume key
Originally Posted by ace_venturia View Post
also check the volume key IC near the volume keys
i've found the ICs defective for keypad not work in 6500s
bro have you got vol key ic jumpring or any oter solution
Old 06-11-2010, 20:24   #19 (permalink)
Member: 996052
Thanks Meter: 35
Originally Posted by dez com View Post
hello i have the display problem change the flex cable still samproblem need chema for display ic 6500S slid
chane display is witch is on the left side by ribbon connector two ic's togather 100000000% work tested
Old 06-24-2010, 10:04   #20 (permalink)
Member: 231751
i hane nokia 6500s all key,s ok but * 0 # keys not working
Old 06-24-2010, 10:05   #21 (permalink)
Member: 231751
i hane nokia 6500s all key,s ok but * 0 # keys not working any help urgently plz...............................
Old 11-15-2010, 13:53   #22 (permalink)
Member: 1335549
Sonork: hussnan
nokia 6500s
i have nokia 6500s
when i remove down kepad ic the upper keys and volume keys are work
when i change down keypad ic or make keypad jumper all keys not work expect power
kindly send me the any solution.
Old 02-19-2011, 09:00   #23 (permalink)
Member: 639546
Thanks Meter: 4
Only my call key is not working rest all is working pls. give me some solution
Old 02-19-2011, 09:42   #24 (permalink)
sunny box's Avatar
Member: 1456392
Sonork: 100.1606104
Thanks Meter: 115
change key pad ic bro........
Old 02-20-2011, 07:38   #25 (permalink)
Member: 639546
Thanks Meter: 4
Changing keypad ic didn't worked for me problem was there in the Keys, i gave jumper from upper key to the call key now its working like a charm.
Old 04-10-2011, 00:22   #26 (permalink)
Member: 996052
Thanks Meter: 35
here is the solution for 6500s key pad problem
1 clean the pcb
2 change the flex if not then
3 change bottom key pad still the same
4 change key pad ic (there is two key pad is's on the pcb top key pad /bottom key pad pad) top ke pad ic is next to two displays ic's and bottom key pad is ic next to keypad connector
5 still the same change the volume key pad ic's there is two cristal ic's in bitween volume button i fix many fone in same problem
Old 10-24-2011, 09:19   #27 (permalink)
Malik Irfan85's Avatar
Member: 1484062
Sonork: 1610135
Thanks Meter: 218
so cute post. . . . .. ..
Old 11-16-2011, 10:39   #28 (permalink)
Member: 1359160
Sonork: 654280
Thanks Meter: 6
Nokia 6500s keypad 123456 not working help
Old 04-27-2012, 08:45   #29 (permalink)
Member: 723248
Thanks Meter: 7
6500 keypad
i have same problem brother please help with good solution
Old 12-07-2012, 18:15   #30 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Originally Posted by i am the master View Post
hello i have one 6500slide key pad problem i change the flex and i changed both key pad ic's but phone is still stock on start up phone without sim card and i can not select anything any solution for this thank you Rash
Just check the Volume switch take off then check if keys are work then change the switch..
nokia 6500s-1 keypad problem nkakanou Nokia Hardware & Hardware Repair 4 06-20-2012 08:33
Nokia 6500 slide keypad (*,0,#) Not working Unique_ah Nokia Hardware & Hardware Repair 8 08-10-2011 17:49
6500 slide keypad problem lijgeorge Nokia Hardware & Hardware Repair 13 04-27-2010 07:36
6500 slide keypad problem lijgeorge Nokia Hardware & Hardware Repair 4 02-07-2009 06:59
Page generated in 0.23248 seconds with 10 queries
