11-15-2010, 13:53 | #22 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1335549 Status: Offline Sonork: hussnan Thanks Meter: 1 | nokia 6500s i have nokia 6500s when i remove down kepad ic the upper keys and volume keys are work when i change down keypad ic or make keypad jumper all keys not work expect power kindly send me the any solution. |
04-10-2011, 00:22 | #26 (permalink) |
Freak Poster Join Date: Mar 2009 Location: uk
Member: 996052 Status: Offline Thanks Meter: 35 | here is the solution for 6500s key pad problem 1 clean the pcb 2 change the flex if not then 3 change bottom key pad still the same 4 change key pad ic (there is two key pad is's on the pcb top key pad /bottom key pad pad) top ke pad ic is next to two displays ic's and bottom key pad is ic next to keypad connector 5 still the same change the volume key pad ic's there is two cristal ic's in bitween volume button i fix many fone in same problem Last edited by i am the master; 04-10-2011 at 00:27. |
nokia 6500s-1 keypad problem | nkakanou | Nokia Hardware & Hardware Repair | 4 | 06-20-2012 08:33 |
Nokia 6500 slide keypad (*,0,#) Not working | Unique_ah | Nokia Hardware & Hardware Repair | 8 | 08-10-2011 17:49 |
6500 slide keypad problem | lijgeorge | Nokia Hardware & Hardware Repair | 13 | 04-27-2010 07:36 |
6500 slide keypad problem | lijgeorge | Nokia Hardware & Hardware Repair | 4 | 02-07-2009 06:59 |
