Old 10-25-2009, 09:59   #1 (permalink)
Member: 1122148
Thanks Meter: 35
nokia 6500c its giving errer in flash
sir i had one nokia 6500c phone it had restartig problem then flash with jaf the SW was 09.48 but in that process phone was n t booting in the end of flash it was failing then itry with hwk it was same
but after that try with hwk with this version rm265__04.84.mcusw now phonegiving this errer
1ST BOOT : C0,07 [Rm-265] [2.0.9.0]
RAPx ID : 000000010000022600010006010C192101003000
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx PBID : 1A300114718C02546AED2F49FD703BC70B19C90A
RAPx MODE : 00
RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
RAPx ROID : 273F6D55DFAAF68F
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00EC220C-00008921, Sam K8F1215ETM
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo_xsr15.fg, Ver: 1.40.0
CMT KSIG0 : D0D8948DEF333BF18141EF4C3D0FB1B002EB5D88
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm265__04.84.mcusw
CMT NOR Erase Area: 0x00000000-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x013C0000-0153FFFF
CMT NOR Erase Area: 0x00140000-013BFFFF
CMT FLASH ERASE OK, Time: 00:57
Written: 8 Certificate(s)
CMT FLASH WRITE OK, Time: 09:44
IMAGE : rm265__04.84_ISM_009.image_m13
CMT NOR Erase Area: 0x01EC0000-03F9FFFF
CMT NOR Erase Area: 0x01BC0000-01EBFFFF
CNT FLASH ERASE OK, Time: 00:50
DATA_BLK_ERROR at: 0x00004000, 00
ERR: CNT FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x004000, Time: 00:04
Process Failed, Repowering Mobile
so what culd be the problem n which SW version will be good for falsh this phone
Thank u
The Following User Says Thank You to shakil143 For This Useful Post:
Old 10-25-2009, 10:48   #2 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
try to flash with latest flash file and use dead usb cable...............
Guljee
Old 10-26-2009, 12:03   #3 (permalink)
Member: 1122148
Thanks Meter: 35
bro can u tell me which the new SW for 6500c
just give SW i wil download from support area
Thank u
Guljee[/QUOTE]
Old 10-26-2009, 12:17   #4 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
Thank u
Bro.try to jaf...
use 7pin cable & agin flash......
Old 10-26-2009, 12:37   #5 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
try to flash with 10.50 version and use dead usb cable.........................
Guljee
Old 11-09-2010, 17:32   #6 (permalink)
Member: 1263622
Thanks Meter: 149
EM 1 ID : 00000295
EM 2 ID : 00000B22
RAPx MODE : 00
CMT 1ST Boot OK
CMT 2ND Boot OK
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
Thank u
bro,flash with UB box after full reset than phone is ok.100%tested
Old 11-10-2010, 06:22   #7 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Thanks Meter: 1,448
Are you crazy if this post is 1 year old are you now answer.......... fast reply hmmmmm
Guljee
nokia 3230 its not coming in normal mode shakil143 Nokia Hardware & Hardware Repair 2 12-04-2009 08:17
nokia 1200 its giving this errer when Flashing shakil143 Nokia Hardware & Hardware Repair 1 11-30-2009 12:45
nokia 1209 its giving this errer flashing time patelfaizu Nokia Hardware & Hardware Repair 1 07-28-2009 08:15
nokia N70 its giving this errer when i m flashing the phone patelfaizu Nokia Hardware & Hardware Repair 4 07-24-2009 17:29
kg800 gives errer after flash imran_bcz ULT PRO 0 02-16-2008 18:41
Page generated in 0.16966 seconds with 9 queries
