10-28-2008, 08:09 | #1 (permalink) |
Freak Poster Join Date: Aug 2007 Location: INDIA
Member: 566051 Status: Offline Thanks Meter: 105 | nokia 6600 after esasing dead ufs log here. 1st Boot: Ok, WD2, UPP: 1081 [Nhl-10] [2.0.8.0] 2nd Boot: w3_2nd.fia, Ver: 4.76.0 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia, Ver: 4.76.0 Algorithm Ok, MSID: 84C4E8C17AAED6BDC566D76898 Decoded MSID: 3E4EBAF7-00DBC40F-A9000000 Encoded FAID: 9E092194-6525DB71-796FFD0A Cbus Boot Error: 9 Error Data1: 00000000: 00 96 84 C4 E8 C1 7A AE D6 BD C5 66 D7 68 98 51 ......z....f.h.Q 00000010: 00 C0 88 00 00 21 01 10 00 04 20 00 C0 88 00 00 .....!.... ..... 00000020: 21 01 10 00 06 20 00 C0 88 00 00 21 01 10 00 FF !.... .....!.... 00000030: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 93 ................ Error Data2: 00000000: B3 72 72 11 00 00 00 00 00 00 00 00 00 00 00 00 .rr............. 00000010: 00 00 21 01 10 00 04 20 00 C0 88 00 00 21 01 10 ..!.... .....!.. 00000020: 00 06 20 00 C0 88 00 00 21 01 10 00 FF FF FF FF .. .....!....... 00000030: FF FF FF FF FF FF FF FF FF FF FF FF 93 D3 72 00 ..............r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile |
The Following User Says Thank You to umesh garg For This Useful Post: |
10-28-2008, 08:13 | #2 (permalink) | |
No Life Poster Join Date: Dec 2005 Location: Roof of the world
Member: 209722 Status: Offline Thanks Meter: 818 | Quote:
10-28-2008, 15:31 | #5 (permalink) | |
No Life Poster Join Date: Feb 2008
Member: 706300 Status: Offline Thanks Meter: 147 | Quote:
" bro do one thing skip bt option & flash, thanx" | |
11-09-2008, 15:04 | #8 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | mobilespeed is right.after skip bt flshing set is on but now is new problem.after on time and date ok show wallpaper then restart again & again.ui setting is not proper .i am posting here.I do manual formate three time but still.any help? Set UI Factory Defaults Failed Set Full Factory Defaults Ok, Time: 01:26 Set Software Upgrade Defaults Ok, Time: 00:00 Set Security Ok, Time: 00:00 IMEI: 356640-00-220851-3, ASIC: 5 SimLocks Initialized (OM Ok), Time: 00:02 Init Normal Mode Failed, no SIM Card |
11-09-2008, 15:27 | #10 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | After jaf flash show "contect ratailor".not done complet flash.log here JAF version 1.98.52 Detected PKEY: 9000C923 Card life counter: 80.73% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.0.2.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.A3 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: O2,IRELAND Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 88C00020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 88C00020 <=> ST -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 88C00020 <=> ST -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x88C00020 Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5808; Loader chk: 61 Loader is ready... P-key nokia module version 01.02 MSID: 84C4E8C17AAED6BDC566D76898 MSID decoded: 3E4EBAF700DBC40FA9000000 FAID: 9E0921946525DB71796FFD0A Operation took 0 minutes 18 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 04000000 - 046FFFFF... Erasing area: 06000000 - 066FFFFF... Erasing area: 047C0000 - 047EFFFF... Operation took 0 minutes 3 seconds... Writing... Perm. Data Restore OK Operation took 2 minutes 16 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.A3 Booting phone... MCU ID: 0x1081 BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x10D8 Boot is ready... FLASH ID0: 88C00020 <=> ST -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 88C00020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 88C00020 <=> ST -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 88C00020 <=> ST -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x88C00020 Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x5808; Loader chk: 61 Loader is ready... P-key nokia module version 01.02 MSID: 84C4E8C17AAED6BDC566D76898 MSID decoded: 3E4EBAF700DBC40FA9000000 FAID: 9E0921946525DB71796FFD0A Operation took 0 minutes 18 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02000000 - 0214FFFF... Operation took 0 minutes 0 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 8 seconds... Restarting MCU... Flashing Done! Operation took 3 minutes 40 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! any flashing mistake?help sir.thanks in advance |
11-09-2008, 15:34 | #11 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: UNITED ARAB EMIRATES Age: 41
Member: 760274 Status: Offline Thanks Meter: 146 | Quote:
Connect jaf..... 1-erase flash 2-write flash 3-write good pm 4-unlock 5-factory settings. Then post result..... | |
11-09-2008, 16:23 | #14 (permalink) |
Freak Poster Join Date: Mar 2005 Location: HYDERABAD
Member: 126000 Status: Offline Sonork: 100.1593044 Thanks Meter: 111 | change mcu&ppm version then check change mcu&ppm version then check.set now same positon that is hardware problem.alredy bletooth notworking. |
11-09-2008, 17:38 | #15 (permalink) |
Member: 566051 Status: Offline Thanks Meter: 105 | mcu and ppm ,tested & latest,I think fault in hardware.main is that after flash set not change in local mode.Have anybody any idea in hardware.Thanks for responce all membar. |
6600s after flash dead??? | Red-1Lotfi | Universalbox | 4 | 06-18-2010 17:49 |
Nokia 6600 after flashing white on then off | naveed malik | Nokia Hardware & Hardware Repair | 7 | 08-14-2008 03:37 |
Nokia 6600 After Flashing Problum | kumar_pvj | J.A.F. Plus | 1 | 06-26-2008 18:22 |
Dead Nokia 6600 after full flash with HWK | said4 | HWK | 6 | 11-02-2007 22:07 |
Nokia 6600 after 15min flip lcd upside-down! | M|kr0naut | WD2 & APE (Symbian Phones) | 3 | 04-03-2004 14:08 |
