Old 06-19-2006, 02:21   #1 (permalink)
Member: 296237
NOKIA 6600 Bluetooth not working,cannot access Gallery
i have a problem with Bluetooth, i can`t enter in bt, galley says opening file and it blocks, i heard that i have to reheat or heat bluetooth,the problem is that im an noob and i don`t even know what reheat means, pls pls pls help me with a good guide about repair bluetooth, im desperate and depresed, please help me
The Following User Says Thank You to bogy16 For This Useful Post:
Old 06-19-2006, 05:01   #2 (permalink)
vipinverma's Avatar
Member: 138224
Thanks Meter: 55
U check supply of bt model?
The Following User Says Thank You to vipinverma For This Useful Post:
Old 06-19-2006, 05:17   #3 (permalink)
bingo_888's Avatar
Member: 234955
Thanks Meter: 19
use JAF to repair bluetoohth, just connect the phone then tick repair bluetooth, or you may reheat or replace bluetooth module
The Following 3 Users Say Thank You to bingo_888 For This Useful Post:
Old 06-19-2006, 05:18   #4 (permalink)
Member: 81216
Thanks Meter: 11
Try to resolder the terminals of the bluetooth module
The Following User Says Thank You to LHOT For This Useful Post:
Old 06-19-2006, 06:03   #5 (permalink)
Member: 296237
o my *** guys u don`t understand that i don`t know what reheat,resolder means, anyway, ive repair it but i don`t know how much it will last, 10x for help anyway
Old 05-26-2008, 03:46   #6 (permalink)
Member: 780029
Thanks Meter: 3
Bluetooth problem
Sir,i dont know wat jaf means.is it any hardware device.can u give me info @ jaf,it will b very helpful to me.hope sir ull surely assist me.thank u
Old 05-26-2008, 03:48   #7 (permalink)
Member: 780029
Thanks Meter: 3
Can anybody assist me how to repair bluetooth
The Following User Says Thank You to Sunil.kammeta For This Useful Post:
Old 05-26-2008, 04:33   #8 (permalink)
Registered User
Member: 195513
Thanks Meter: 67
my friend the best solution is remove the bt cover and change the first ic which is located at the top of the bt module.this will surely solve your problem.you can get same ic from 3650 bt module,they are the same.
The Following User Says Thank You to glenntelecom For This Useful Post:
Old 05-26-2008, 04:44   #9 (permalink)
Member: 777423
Thanks Meter: 9
sir much better to replace one set of bluetooth module to solved your problem.....
The Following 3 Users Say Thank You to casperlink26 For This Useful Post:
Old 05-26-2008, 04:55   #10 (permalink)
Member: 661024
Thanks Meter: 6
Hi bogy,just put this code *#2820# if ur set give bluetooth address then just repair bluetooth with UFS(software repair box),if not given address rehot(give some heat with ****er)with good flux(paste).
The Following 2 Users Say Thank You to bob1_2007 For This Useful Post:
Old 05-26-2008, 08:40   #11 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
Brother its Blue Tooth Module problem, change it and post result.
The Following User Says Thank You to Sagitarious For This Useful Post:
Old 05-26-2008, 08:52   #12 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
change the bluetooth ic............and cheak gallery is open properley and bluetooth work 100%
The Following User Says Thank You to prakash6464mh For This Useful Post:
Old 05-26-2008, 11:19   #13 (permalink)
psilva's Avatar
Member: 468642
Thanks Meter: 36
change the bluetooth module and your phone open galery and bluetooth work 10000%
The Following User Says Thank You to psilva For This Useful Post:
Old 05-27-2008, 09:40   #14 (permalink)
Vijendra Saini's Avatar
Member: 398557
Sonork: 100.1578489
Thanks Meter: 1,513
Wink BT Module.
Its an hardware fault try to rehot BT module or replace it.
Thankz.
Xtreme Mobile.
BRB.
File Type: jpg 6600 galery-bluetooth rehot solution.jpg (40.1 KB, 978 views)
The Following 5 Users Say Thank You to Vijendra Saini For This Useful Post:
Old 06-16-2008, 09:29   #15 (permalink)
sujan1050's Avatar
Member: 449518
Thanks Meter: 585
thanks prakash for sharing..............keep posting
The Following 2 Users Say Thank You to sujan1050 For This Useful Post:
NOKIA 6600 Bluetooth not on & off help me palav Nokia Hardware & Hardware Repair 2 09-21-2009 20:16
6600 bluetooth not work vikas kumar Nokia Hardware & Hardware Repair 11 11-17-2008 04:13
NHL-10 6600 Bluetooth not work googlesw WD2 & APE (Symbian Phones) 2 08-18-2006 22:16
6600 BT not working n Open Gallery hpcom Nokia Hardware & Hardware Repair 8 07-02-2006 09:39
Nokia 6600 LCD not working properly, no camera function ! NaaN WD2 & APE (Symbian Phones) 3 01-18-2004 11:35
Page generated in 0.46351 seconds with 9 queries
