09-04-2009, 11:43 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2006
Member: 276537 Status: Offline Thanks Meter: 31 | nokia 6600 contact servive i have a nokia 6600.when I got the phone ,phone have a problem of contact service. I clean that very well and gave heat. After that flashed with JAF.now phone is getting turn on and get the same problem. Here in below are the LOG details. Please some one can help me to solve it how to fix the problem? Advance thanks… Ranjieet karmackar Getting MCU ID MCU ID: 0x0082 FLASH ID0: 88BE0020 <=> ST -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 88BE0020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 88BE0020 <=> ST -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 88BE0020 <=> ST -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... Setting local mode... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.C1 PPM Flash file: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.02 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French (Euro A/ZA) Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.C1 PPM Flash file: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.01 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,French (France) Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.C1 PPM Flash file: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.05 CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,German,Italian (Italy) Backing up PM Field 208 as RPL... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Programmi\ODEON\JAF\ProgData\352956009399095_im ei_backup_12149.rpl Done! Backup imei OK! MCU: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.C1 Booting phone... MCU ID: 0x0082 BOOT file: C:\Programmi\ODEON\JAF\Flash\w2_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x1058 Boot is ready... FLASH ID0: 88BE0020 <=> ST -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 88BE0020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 88BE0020 <=> ST -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 88BE0020 <=> ST -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x88BE0020 Flash loader is C:\Programmi\ODEON\JAF\Flash\w2_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x56B0; Loader chk: eb Loader is ready... P-key nokia module version 01.02 MSID: 84B4E0247DEA3CDB214DB3CC02 MSID decoded: 3E4EBAF700405672AA000000 FAID: 5CAF919915F1CCA3C130F6E6 Operation took 0 minutes 18 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 00010000 - 007FFFFF... Erasing area: 04000000 - 046FFFFF... Erasing area: 06000000 - 066FFFFF... Erasing area: 047C0000 - 047EFFFF... Operation took 5 minutes 52 seconds... Writing... Perm. Data Restore OK Operation took 3 minutes 0 seconds... Restarting MCU... PPM: C:\Programmi\Nokia\Phoenix\Products\NHL-10\NHL104091.05 Booting phone... MCU ID: 0x0082 BOOT file: C:\Programmi\ODEON\JAF\Flash\w2_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x1058 Boot is ready... FLASH ID0: 88BE0020 <=> ST -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10 FLASH ID1: 88BE0020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10 FLASH ID2: 88BE0020 <=> ST -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10 FLASH ID3: 88BE0020 <=> ST -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10 First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA Flash ID is 0x88BE0020 Flash loader is C:\Programmi\ODEON\JAF\Flash\w2_st_i.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x56B0; Loader chk: eb Loader is ready... P-key nokia module version 01.02 MSID: 8499A1482360417EDF1951F71F MSID decoded: 3E4EBAF700405672A8000000 FAID: EDE0B9516D55F8A880D45656 Operation took 0 minutes 19 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 00000000 - 0000FFFF... Erasing area: 02000000 - 0213FFFF... Operation took 0 minutes 22 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 11 seconds... Restarting MCU... Flashing Done! Operation took 10 minutes 7 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: NHL-10, Software version: 4.09.1 IMEI: 352956009399095 Product Code: 0511172 Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Failed! Aborting! Failed! Aborting! Done! |
09-04-2009, 12:32 | #2 (permalink) | |
Insane Poster Join Date: Mar 2008
Member: 721821 Status: Offline Thanks Meter: 10 | Quote:
sir...........flash ic sum of them are 00 i hope i can help | |
nokia 6600s contact service | samih127 | Nokia Base Band 5 ( BB-5 ) | 5 | 06-24-2009 06:44 |
nokia 6600 contact retailer | ahmed nokia | WD2 & APE (Symbian Phones) | 7 | 04-03-2007 10:07 |
Nokia 6600 CONTACT RETAILER... And UFS3.... :( | Shagron-GSM | UFS2 + UFS3-Tornadoflasher | 12 | 12-15-2004 15:20 |
nokia 6600 contact retailer | karouk | WD2 & APE (Symbian Phones) | 5 | 10-28-2004 10:46 |
