Old 03-08-2005, 02:05   #1 (permalink)
Member: 69633
Thanks Meter: 2
Exclamation Nokia 6600 keypad prob. Both IC's replaced and keypad works for only few hours. HELP!
Got 3 nokia 6600 sets. All with keyboard problems. Key entries are sometimes stuck (as if key if continuously pressed) or key/s does not work at all. Keypad membrane 100% not the problem.
Keyboard IC's near connector are replaced from other dead handsets and phone works perfect only for a few hours!! Then starts giving probs till all keys don't work anymore.
Replacement IC's are now ALL bad.
Any ideas please HELP !
Old 07-13-2005, 10:27   #2 (permalink)
belenm40's Avatar
Member: 147220
Thanks Meter: 31
6600kry pad notworking
hello i have also 2pcs 6600 keys 8 and left camera keys not working any solution
Old 07-13-2005, 10:34   #3 (permalink)
belenm40's Avatar
Member: 147220
Thanks Meter: 31
hello i have also 2pcs 6600 keys 8 and left camera keys not working any solutionand when u press 8 it writes 2 and whin u press2 it writes 2
Old 07-13-2005, 10:46   #4 (permalink)
Cheater -Don't Deal with him-
chiragp's Avatar
Member: 106367
Sonork: 100.1577436
Thanks Meter: 2,452
u must heat the uem if it is not fixed with glue use some liquid flux still not working then **** the cpu bye
Old 10-17-2005, 08:32   #5 (permalink)
Burnt Cobba's Avatar
Member: 11325
Thanks Meter: 266
this is the only way to try to fix such a problem ?
met 5 6600s and 3 7610s damn
al
All chinese ic's name and there working Mr. Right Chinese Models & Cloned Phones 0 12-21-2008 14:00
2600 keypad works for only 4 seconds shirly Nokia Hardware & Hardware Repair 1 04-29-2006 07:42
6100 lcd work only few hours iki Nokia Hardware & Hardware Repair 10 02-10-2006 17:51
for only 48 hour only a800 arabic flash freeeeeeeeeeeeeeee fonec VLSI, Conexant, Skyworks and Old Models 15 03-28-2003 02:24
Page generated in 0.17809 seconds with 9 queries
