07-11-2008, 15:42 | #1 (permalink) |
Freak Poster Join Date: Jul 2008 Location: P A K I S T A N
Member: 805902 Status: Offline Thanks Meter: 31 | nokia 6600 keypad problem press and when press 7;8; or 9 then end key is pressed i have changed both key pad ic,s and upper pannel..... butt problem not solved any one have solution so plzzz reply |
07-11-2008, 15:50 | #2 (permalink) |
Freak Poster Join Date: Aug 2007 Location: india
Member: 572872 Status: Offline Thanks Meter: 21 | 100% Problem Solve With Changing Keypad Ic. Change Both Keypad Ic Carefully.as They Arenear Flash Ic Because Of Which Handset Can Be Dead. Change Keypad Ics Carefully. |
07-11-2008, 16:34 | #3 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | @cellsolutions1 Problem surely in keypad ic. see this solution: 1) remove both ic's 2) clean pbc surface where ic can be fixed. 3) install first upper ic with new one. then check on pressing 4 5 6 still send key press or not if it works ok then 4) install next ic. |
The Following 3 Users Say Thank You to KK Mobile For This Useful Post: |
Nokia 6600 Keypad Problem | Ankit Verma | WD2 & APE (Symbian Phones) | 7 | 11-27-2010 13:02 |
Nokia 6600 keypad problem | vali.rusu | Nokia Hardware & Hardware Repair | 5 | 08-30-2010 23:34 |
Nokia 6600 keypad Malfunction, Pls help!!! | kaino147 | Nokia Hardware & Hardware Repair | 7 | 10-10-2007 12:57 |
Nokia 6600 Keypad crystal IC problem | sajidrana | Nokia Hardware & Hardware Repair | 5 | 09-22-2007 23:47 |
Nokia 6600 keypad prob. Both IC's replaced and keypad works for only few hours. HELP! | dizzu | Nokia Hardware & Hardware Repair | 4 | 10-17-2005 08:32 |
