04-15-2006, 22:14 | #3 (permalink) |
Insane Poster Join Date: Feb 2006
Member: 234532 Status: Offline Thanks Meter: 25 | Evry time use serch buton befor posting.For now click this link: [url]http:///vbb/showthread.php?t=221053&page=7&highlight=nokia+660 0 shirly Last edited by shirly; 04-15-2006 at 22:28. Reason: url was not ok |
04-15-2006, 22:56 | #4 (permalink) | |
Freak Poster Join Date: Feb 2006 Location: pakistan
Member: 232662 Status: Offline Thanks Meter: 58 | Ismail Khan Quote:
first you write main pm and unlock do full UI factory defoult after this check if still same try to check connect jumper i attach jumper picture and check also same no signal try to change this small antiena hope you i'll success thanks BR, ISMAIL KHAN Last edited by tommobil2005; 04-15-2006 at 23:21. | |
06-28-2007, 08:38 | #9 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | Dear ISMAIL KHAN , using Manual network search "no operator found" in less than 3 seconds. RXTXDUP (swant) is ok(changed form working phone),RF IC OK,I rehot UPP too,changed 26MHz crystal. No change.PM is ok |
The Following User Says Thank You to .::AkhavanGSM::. For This Useful Post: |
06-28-2007, 09:38 | #10 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 192146 Status: Offline Thanks Meter: 46 | If your phone cannot search network in less than 3 seconds it could be in FDK or low filter!!! Check first before U take some shot on other IC!!!!!!! Good Luck.... Dee31. |
The Following User Says Thank You to Dee31 For This Useful Post: |
Help... Nokia 6600 - no signal on speaker, no signal on buzzer. | Normunds | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 08:20 |
6600 no signal | classic mobiles | WD2 & APE (Symbian Phones) | 4 | 04-16-2006 14:23 |
6600 no signal after flashing | Riempies | WD2 & APE (Symbian Phones) | 8 | 11-25-2005 14:02 |
need help 6600 no signal | mrpandya | Nokia Hardware & Hardware Repair | 1 | 04-26-2005 08:18 |
6600 no signal | jln310 | WD2 & APE (Symbian Phones) | 0 | 06-10-2004 10:39 |
