Old 10-18-2008, 01:47   #1 (permalink)
asif_ae's Avatar
Member: 334999
Thanks Meter: 225
nokia 6600 only shows nokia with battery not software {like HWK}
sir when i flash the nokia 6600 then after flash, i do reseting and reboot in normal mode then phoneworking perfect and open all menu, but when i insert battery then it hang on nokia logo with white lights and not going forward.i try many flash files but problem is same kindly help me
The Following User Says Thank You to asif_ae For This Useful Post:
Old 10-18-2008, 01:51   #2 (permalink)
rafzkie_24's Avatar
Member: 614098
Thanks Meter: 192
bro...
try to format user area 4 times......
if no luck.....
replace zocus location above the baterry terminal............
if no luck again.....
mildly reheat or reball upp........
or replace upp......
goodluck.......
br,
The Following User Says Thank You to rafzkie_24 For This Useful Post:
Old 10-18-2008, 12:18   #3 (permalink)
sood's Avatar
Member: 812373
Thanks Meter: 47
Chack imei no. In phone i think empty
chack and post hear
Old 10-18-2008, 16:57   #4 (permalink)
Member: 654510
Thanks Meter: 21
100% it is the complant of boot ic (smps)............change or reball........
good luck...
The Following User Says Thank You to naima For This Useful Post:
nokia n81 only show nokia ranagaurav MXKEY Nokia Flasher and Unlocker (by Alim Hape) 11 03-03-2010 23:27
n70 only show nokia no light not move next step m_takmeel Nokia Base Band 5 ( BB-5 ) 1 04-25-2009 11:34
Nokia 3250 Only Showing NOKIA Pls help naim_007 Nokia Hardware & Hardware Repair 10 10-27-2008 11:59
Page generated in 0.16000 seconds with 9 queries
