Old 06-13-2008, 15:38   #1 (permalink)
rajtelecom's Avatar
Member: 446363
Sonork: 1577571:rajtelecom
Thanks Meter: 216
nokia 6600 white light
phone flashing ok but no result
phone still white light
JAF version 1.98.50
Detected PKEY: 900032FF
Card life counter: 83.09%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105270.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105270.02
Languages in ppm: English,German,French (Euro A/ZA)
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.A3
Languages in ppm: O2,IRELAND
Backing up PM Field 208 as RPL...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.C1
Booting phone...
MCU ID: 0x1081
BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x10D8
Boot is ready...
FLASH ID0: 277E0001 <=> SPANSION -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
FLASH ID1: 277E0001 <=> SPANSION -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
FLASH ID2: 277E0001 <=> SPANSION -> Type not in database Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
FLASH ID3: 277E0001 <=> SPANSION -> Type not in database Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 10
First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Flash ID is 0x277E0001
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
Loader size is 0x7F10; Loader chk: 88
Loader is ready...
MSID: 84ED2340B86E635A8B941D4EE1
MSID decoded: 3E4EBAF70011B062A9000000
FAID: 65FAE539AA5BC6322A34D5A4
Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_cbusb.fia
Loader size is 0x2020; Loader chk: 7f
Additional Loader is ready...
Operation took 0 minutes 25 seconds...
Erasing...
Found 5 interval(s) to erase
Erasing area: 00000000 - 0000FFFF...
Erasing area: 00010000 - 007FFFFF...
Erasing area: 04000000 - 046FFFFF...
Erasing area: 06000000 - 066FFFFF...
Erasing area: 047C0000 - 047EFFFF...
Operation took 2 minutes 42 seconds...
Writing...
MCM Register OK
Perm. Data Restore OK
Operation took 3 minutes 1 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\NHL-10\NHL105530.A3
Booting phone...
MCU ID: 0x1081
Boot size is 0x10D8
Boot is ready...
First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
Loader is ready...
Operation took 0 minutes 21 seconds...
Erasing PPM...
Found 2 interval(s) to erase
Erasing area: 02000000 - 0214FFFF...
Operation took 0 minutes 10 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 7 minutes 22 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: NHL-10, Software version: 5.53.0
IMEI: 359365004909101
Product Code: 0526091
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 58 seconds...
Done!
Done!
Powering the phone...
Unlocking...
IMEI: --------------
ASIC: 5
SW version: 5.53.0
Checking locks...
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 500
Reading imei...
IMEI/ESN: *************
Reseting warranty data...
Reseting LifeTimer...
Lifetime data not found!!!
Done!
The Following User Says Thank You to rajtelecom For This Useful Post:
Old 07-24-2008, 11:20   #2 (permalink)
rajtelecom's Avatar
Member: 446363
Thanks Meter: 216
####....problem solved....####
Old 07-26-2008, 09:27   #3 (permalink)
Member: 254941
Thanks Meter: 24
how did u solve this problem. pls post
Old 09-15-2008, 02:09   #4 (permalink)
rajtelecom's Avatar
Member: 446363
Thanks Meter: 216
cheng boot ic b'nd battery conector
Old 11-01-2008, 07:31   #5 (permalink)
Member: 618788
find a good fullerase pm for 6600 t
6600 White Lights Only PARMATMA Nokia Hardware & Hardware Repair 17 08-30-2008 17:06
Nokia 6600 White Light & Vibrate Continusly Ankit Verma Nokia Hardware & Hardware Repair 2 07-19-2008 19:08
6600 white light & keypad light blink 9 times shoeb7 Nokia Hardware & Hardware Repair 5 06-13-2008 15:30
nokia 6600 WHITE LIGHT. INCOMMING AND OUTGOING CALLS ARE OK. shahi Nokia Hardware & Hardware Repair 3 12-17-2007 07:30
pls any one one guide me in 6600 white light digitized Nokia Hardware & Hardware Repair 5 06-03-2007 03:50
Page generated in 0.24780 seconds with 9 queries
