02-02-2006, 14:53 | #1 (permalink) |
Banned Join Date: Dec 2004 Location: MX-KEY is the BEST NOKIA TOOL Age: 51
Member: 101683 Status: Offline Thanks Meter: 26 | 6610i insert card problem !!! i have 6610i after water damage it say insert sim card ,i clain the boord very good but the ame problem , i make like picture but it say insert card , what can i do ????? any idia about thi problem ??? thankes to all ... |
The Following User Says Thank You to waleed2500 For This Useful Post: |
02-02-2006, 15:55 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | you see your picture? you must first test for continuity the points in the big picture (from sim esi filter to sim reader connector). if there is continuity then no rason to bridge. really, you should be making bridge like in the smaller picture after remove the small filter IC (it looks like glass or crystal). try that |
02-02-2006, 17:52 | #3 (permalink) |
Member: 101683 Status: Offline Thanks Meter: 26 | thankes mr. Dave.W to u replay ,but i tested the continuity it work good , so i make the bridge but no change the same broblem, any new aidia ???? |
02-03-2006, 20:06 | #5 (permalink) |
No Life Poster Join Date: Jun 2003 Location: egypt,alexandria,(nassimgroup team) Age: 48
Member: 31018 Status: Offline Thanks Meter: 3 | You Say It Water Damage I Don't Wanna Shock You But It Seems Like Uem Probleme Mate But First You Should Check Well Your Board And That Small Pics With Small Connections Should Be Made You Use This Big One When The Sim Card Set Is Taken Off From Its Place First Check Your Connections Well The Last Thing You Think In Is Uem |
02-04-2006, 02:03 | #6 (permalink) |
No Life Poster Join Date: Feb 2002 Location: germany Age: 49
Member: 9584 Status: Offline Thanks Meter: 31 | http://www.gsm-sos.de/main/index.php...f4c478376c778a this will solve your problem |
difficult to make a jump to SIM insert card problem | mokhtarz | Nokia Hardware & Hardware Repair | 4 | 04-19-2007 23:13 |
e330 insert card problem | lamine | Samsung Hardware Repair | 0 | 01-02-2006 18:27 |
Fisio 311 insert card problem??? | proxy_gsm | Philips | 0 | 10-05-2003 20:23 |
8310 insert card problem... | ZORK | Nokia Hardware & Hardware Repair | 3 | 10-29-2002 19:49 |
Insert card problem! | Meam | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 09-07-2002 14:26 |
